f250 tow rig question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2008, 11:55 AM   #1
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
Default f250 tow rig question
I m looking at a 1992 f250 with the fi 460, the truck is in imacculate shape with 68k origional miles, it was used to tow a 5th wheel to florida in the winter and back to michigan in the spring, i know the gas milelage wont be great(please no ''its gonna suck dude'' responses, just looking for the numbers) but was wondering how bad, anybody use this set up? thanks in advance. bb
broncobuddha is offline   Reply With Quote
Old March 20th, 2008, 12:02 PM   #2
bearlys2005
bearlys2005's Avatar
I had an 89 F350 crew 4X4 FI 460 and non OD trans. It would haul anything and the best mileage I ever got was 10 MPG running empty on the highway. I didn't even want to know what it was hauling a load but it was worse. It was a great tow rig if the gas doesn't bother you.
bearlys2005 is offline   Reply With Quote
Old March 20th, 2008, 12:24 PM   #3
broncobuddha
Starting over
this one has the od trans, the mileage thing is a bit scary, i wouldnt really even consider it but this truck looks like new, absolutly no rust at all, and it would only be used for towing no dd ing
Old March 20th, 2008, 12:29 PM   #4
bearlys2005
I don't worry about the mileage... Were going to play so i don't think about it too much. Sounds like a great tow rig...
Old March 20th, 2008, 12:32 PM   #5
broncobuddha
Starting over
i hear ya, i just cant believe the shape this thing is in, and with a full size bronco to tow it would be a good rig, if i dont wind up buying it I m going to ask the owner if i can post it here for her, it literally looks like a new truck
Old March 20th, 2008, 12:33 PM   #6
LILL ZJ
LILL ZJ's Avatar
i never touch overdrive when i'm towing.90 1/2 ton extended cab... not the same i know as a one ton but still would you use overdrive towing another vehicle with a loaded trailer?
LILL ZJ is offline   Reply With Quote
Old March 20th, 2008, 12:34 PM   #7
LILL ZJ
LILL ZJ's Avatar
By the way i get about 12 on a good day for a small 350 in overdrive empty. I wish i had a big block anyways.
Old March 20th, 2008, 07:15 PM   #8
sledder
2257 Compliant
sledder's Avatar
I had a 96 250 crew cab with the 460 automatic w/od. Would get about 7 mpg towing a 30ft travel trailer. Maybe 12 empty. Beautiful truck, loved it. Could tow anything up a telephone pole. Just have to stop halfway up for gas.
sledder is offline   Reply With Quote
Old March 20th, 2008, 11:51 PM   #9
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
My buddy had a 97 F350 crew cab long box. 460ci AOD tranny 4.10 gears and 285's tires. I used his truck a few times, best I got for mileage was 12mpg. He used to tow a good size gooseneck flat bed full of beams from barns. Pretty heavy load, and he got anywhere from 8-10mpg. The truck did have duel tanks.....and you used them both all the time.
Old March 21st, 2008, 12:38 AM   #10
broncobuddha
Starting over
thanks guys, exactly what i needed to know!
Page generated in 0.21908 seconds with 53 queries
