SRW vs. DRW - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 17th, 2008, 01:04 PM   #1
pizzaman
pizzaman's Avatar
Default SRW vs. DRW
Speaking in terms of a Chevy Dana 60 front and rear axle, what are the pros and cons of a SRW vs a DRW? Is one better than the other and is there a preference.
What else should be looked at in regards to these axles besides kingpin or ball joint.
Thanks
pizzaman is offline   Reply With Quote
Old March 17th, 2008, 02:52 PM   #2
Blackjackbender
srw is narrower
drw is wider.
most people go for single rear wheel so there width isn't super wide. but i have seen a couple people run DRW with H1 rims.
a DRW axle can be converted to SRW if you change the hubs. There is a way to convert a DRW hub to SRWish width but it requires some machining and welding to the hub. much easier just to buy a set of hubs.
Old March 17th, 2008, 02:53 PM   #3
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
chevys are all kingpin, drw works good if you are running stock H1 wheels
Old March 19th, 2008, 03:09 PM   #4
bigblazer
ditch digger
Usually DRW can be found cheaper, other that that there the same. I just got done turnning down a set of DRW hubs for my front. They look like there gonna work pretty good.
bigblazer is offline   Reply With Quote
Page generated in 0.17542 seconds with 35 queries
