front axle alignment - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 17th, 2008, 12:42 PM   #1
Grassman
2jz specialist
Grassman's Avatar
Default front axle alignment
what is the proper angle to set a front axle caster to, and where do you measure from?
my educated brain says measure from the top of the knuckle, how far back should i go?
its for a D44 on a 89 xj running 37's
Old March 20th, 2008, 05:58 PM   #2
Grassman
2jz specialist
Grassman's Avatar
bump
Old March 24th, 2008, 09:29 PM   #3
1crazyredneck
MichiganRednecks
1crazyredneck's Avatar
I just got done with a JK lift.. RE long arm.. With the arms screwed all the way in I could only muster 2.5deg of caster.. Although it goes down the road it's still a little shoppin'cart'like for me.. I'm going to cut the threads a little and take it back further to at least 4deg.. So I'd say 4deg min but some others might no better.
1crazyredneck is offline   Reply With Quote
Old March 24th, 2008, 09:33 PM   #4
russellmn
I like to have 5-8* pos. caster. If you're not doing a cut and turn of the knuckles you kinda have to compromise between good caster angle and good pinion angle. If you can do it without a bad pinion angle, get at least 5* and you'll be happy.
russellmn is offline   Reply With Quote
Old March 25th, 2008, 12:18 AM   #5
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
3 to 5 should be fine. The bigger the tire, the less caster you need.
JcrOffroad
Zoom Zoom!
Page generated in 0.17407 seconds with 38 queries
