What determines towing capacity? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 16th, 2008, 02:40 PM   #1
redmud
10 0011 10101
redmud's Avatar
Default What determines towing capacity?
Kicking around the idea of buying a tow rig this summer, I can't really go as big with my jeep as I want to until it's got a hauler. I don't honestly have much use for a pick up- I live 7 minutes from work and don't need to haul anything. BUT- I'd really like a vehicle that can tow the jeep on a trailer, be a DD and maybe have luxuries like glass windows :tonka:. So, if I'm looking at say a FS Bronco or maybe a short Suburban or possibly a ZJ/WJ with a V8, what really determines towing capacity?
Frame rigidity?
Tire/Axle size?
HP?
Leaves Vs. Coils and Links? (Not sure about Tahoes and Grand Cherokees for this reason)
what's the most important?
BDS Suspension
How can you land a space ship on the moon? How can a snake eat an aligator? how does the internet work? some questions are not meant to be answered by man alone.
redmud is offline   Reply With Quote
Old March 16th, 2008, 05:10 PM   #2
ksejeeper
Money pit
ksejeeper's Avatar
Send a message via Yahoo to ksejeeper
the Gross vehicle weight is mostly it, or what every the manufacture says it can handle. for me as an example. My F-150 has a GVW of 7300lbs and I have a class IV hitch (rated to 7500lbs) the most I can haul is 7300lbs (14600lbs total truck and trailer/load).
2012 Can-Am commander 1000 X
2014 Ram 3500 Meg Cab 4x4 6.4 Hemi Blacked out edition.
ksejeeper is offline   Reply With Quote
Old March 16th, 2008, 05:49 PM   #3
scottie
Eye candy
scottie's Avatar
Lawyers, and Warranties
Old March 16th, 2008, 05:58 PM   #4
88yj
collecting parts
88yj's Avatar
Send a message via AIM to 88yj
Yes. Vehicles get tow ratings based on testing for overheating, braking when loaded, and acceleration when loaded. There are also durability tests to determine how long the components will live when towing a certain amount.
I personally think lots of vehicles are over-rated in the towing dept these days. Wheelbase is a big factor for me personally when choosing a tow vehicle. Tow with something too short and you'll figure it out quickly.
88yj is offline   Reply With Quote
Old March 16th, 2008, 06:10 PM   #5
XXXJ
Desert Rat
XXXJ's Avatar
Actually it is the GCVW: Gross Combined Vehicle Weight. That is the rated GVW of your vehicle plus the weight of your trailer on contents. They have a tenedncy to overate the vehicles. Which means you can pull it, under optimal conditions.
I've seen a fair share of 1/2 ton and SUVs overloaded on the open road. Some people doing some pretty scary shit out there.
The difference between genius and stupidity is that genius has its limits" - Albert Einstein
Do yourself a favor and go 3/4 ton if you can.
Old March 16th, 2008, 06:11 PM   #6
scottie
Eye candy
scottie's Avatar
yes i know how vehicles get tested, but on half the cars i think they pull the number out of a hat and see what the competition has to say, then ask the lawyers
Old March 16th, 2008, 06:22 PM   #7
XXXJ
Desert Rat
XXXJ's Avatar
one of my favorites
Old March 16th, 2008, 07:03 PM   #8
88yj
collecting parts
88yj's Avatar
Like how Ford suddenly upped the F-150's tow rating after Tundra came out?
Old March 16th, 2008, 07:34 PM   #9
redmud
10 0011 10101
redmud's Avatar
that's exactly what I want to avoid: I've seen some scary crap on the e-way myself over the years... My thing is that I don't really have a need for a gigantor truck, and at 4+ a gallon, a diesel is certainly out. I don't want to overload a Grand Cherokke, and I know people who tow with them, but it seems a bit small for dragging a jeep and trailer around. I'm thinking about finding a late Bronco, maybe.
BDS Suspension
Old March 16th, 2008, 07:52 PM   #10
scottie
Eye candy
scottie's Avatar
just get a 1/2 ton truck then, fuel mileage won't be that different from a Full size bronco.
and the longer wheelbase will only help it on the highway.
or split the difference and a get a Tahoe
Old March 16th, 2008, 08:11 PM   #11
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I agree, and think some are underated. My '99 Suburban with 5.7L and 3.73 gears is only rated to tow 6000lbs. but my 95 ZJ w/4.0L is rated for 5000lbs. My '01 Explorer Sport Trac w/4.0L is rated to tow 5500lbs. How can those two small 6cylinder vehicles be rated just under what the big Suburban is rated for. I also think the Suburban is underated.
Old March 16th, 2008, 08:18 PM   #12
mokerlund17
mokerlund17's Avatar
Send a message via AIM to mokerlund17
a 90s z71 extended cab with a 350 the one i had pulled like a champ. the vehicle plays a big part but ability and knowing your limits is bigger
mokerlund17 is offline   Reply With Quote
Old March 16th, 2008, 08:18 PM   #13
Nuggets
I fix stuff!
Nuggets's Avatar
When it comes to towing, the heavier the tow vehicle, the better your towing experiance will be. If you have a 2000 pound trailer and 4500 pound jeep (assuming its on the heavier side), you should be ok with a 1/2, or 3/4 ton pickup. If you want to spend the bucks and need something to pile the family in than I would suggest a Suburban.
Old March 16th, 2008, 08:26 PM   #14
Mclovin
"The Situation"
Mclovin's Avatar
towing your TJ you're gona need AT LEAST a F-450 Super Duty if not a Gm kodiak .. hope that helps
Old March 16th, 2008, 08:34 PM   #15
XXXJ
Desert Rat
XXXJ's Avatar
Remember those published numbers are the max rated GCVW. As you approach or exceed those numbers your safety factor decreases. If your rated at 5k and towing 5k you might want something more.
I personally don't like towing with IFS anything, but thats just preference.
And just to keep things in perspective, I can visualize the difference between a Dana 35/44 axle and a Dana 60/70.
A half-ton pick up is for towing a couple sleds and transporting the family dog or occassional fat chick.
Old March 16th, 2008, 08:34 PM   #16
lgottler
lgottler's Avatar
I first look at the weights. If what I'm towing with is close to what I'm pulling, I'm OK. But if your tow rig is lighter than the load, I be scared unless you take proper precautions (the right brakes, the right hitch, the right tires, the right trailer, etc...)
My parents '03 Yukon with 5.3L & 3.73's is rated higher than my '94 burb with 7.4L & 4.10's 3/4ton....for sale BTW...
Lucas
lgottler is offline   Reply With Quote
Old March 16th, 2008, 09:28 PM   #17
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Lucas
No its not, your Suburban is rated to tow 10,000lbs. That Yukon is probably around 7500lbs
Old March 16th, 2008, 09:30 PM   #18
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
You mean like if your rated to tow 6000lb and you are towing about 8000lbs?:tonka:
Old March 16th, 2008, 09:32 PM   #19
Mclovin
"The Situation"
Mclovin's Avatar
Lucas
you forgot to add "the right driver" in there.. you can have the most badass tow setup every but if you throw some Johnny Geo Drive behind the wheel who's never driving anything big before in there.. Everyone's fucked
Old March 17th, 2008, 07:12 AM   #20
redmud
10 0011 10101
redmud's Avatar
Can I park it at your place? :tonka: I can barely fit 3 cars in my driveway, and the Jeep won't fit in the garage anymore. I'm thinking a mid-90's something. What about a reg cab 3/4 ton?
AND: Does it have to be 4wd? Does that make a difference in towing ability? Other than on snow?
BDS Suspension
Page generated in 0.65741 seconds with 83 queries
