Wheel Barrings! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 16th, 2008, 01:09 PM   #1
*MudKing*
Curious
*MudKing*'s Avatar
Default Wheel Barrings!
im fucking pissed!
i replaced my whole hub assembely and both wheel barrings 2 weeks ago.
i recently noticed that when i jack up that wheel i can wiggle it like the barrings are worn!!!!
damnit i just replaced everything in th fucking hub! what is wrong with my front end!
*MudKing* is offline   Reply With Quote
Old March 16th, 2008, 01:20 PM   #2
BlackBetty97
We Like it Loud
BlackBetty97's Avatar
Sounds like you didnt tighten up that outer locknut enough. I torque em down to 250 foot pounds.
BlackBetty97 is offline   Reply With Quote
Old March 16th, 2008, 01:26 PM   #3
*MudKing*
Curious
*MudKing*'s Avatar
Holy shit, is that the locknut before the 4wd locker?
the nut that holds the hub on?
Old March 16th, 2008, 01:29 PM   #4
clarkstoncracker
lol
clarkstoncracker's Avatar
Old March 16th, 2008, 01:32 PM   #5
kickstand
circling the drain
kickstand's Avatar
Originally Posted by *MudKing* View Post
im fucking pissed!
You may want to clarify, it sounds as if you are working on a truck with re-buildable wheel bearings vs a truck with unit bearings?
If my assumption is correct did you also change the races when you did the bearings? What condition is the spindle in? Did you in fact torque everything down to factory specs? Did you fully pack the bearings with grease? Did you buy nice quality bearings? Something is also warn out or you did the job improperly.
If my assumption is incorrect and you purchased unit bearings I will bet 5 dollars you got the shitty ones from autozone.
Old March 16th, 2008, 01:34 PM   #6
*MudKing*
Curious
*MudKing*'s Avatar
Damnit!!!!!
Old March 16th, 2008, 01:36 PM   #7
xj97sport
atv rider
xj97sport's Avatar
ha ha (nelson voice)
Old March 16th, 2008, 09:13 PM   #8
chris1044
chris1044's Avatar
im fucking pissed!
So what is your question???
I'm going to assume you have a TIB/TTB front end....just an FYI, torque specs actually matter when doing those wheel bearings, and just as a precaution (or prevention of what happened to you) I check my wheel bearings at ~100 miles and then 500 miles after I do them.
Really though, it's not that hard to make them last - mine have roughly 40k on them now....lifted truck with bigger tires....
Old March 16th, 2008, 09:17 PM   #9
what Chris siad, also what Front end and what style hubs......
Assuming your avatar pic is the truck????
some of the 44 hubs are not the two nuts with the lock washer. Some had a one nut ratcheting style assm.
Old March 16th, 2008, 09:47 PM   #10
*MudKing*
Curious
*MudKing*'s Avatar
i have been working on it and discoverd that the ratcheting locknut came loose, i tightend it back up and it seems to be all good. but this makes me think that the locknut isnt workin, can i buy a new one?...
Old March 16th, 2008, 10:06 PM   #11
bj house
bj house's Avatar
depends you have any income
Old March 16th, 2008, 10:57 PM   #12
bronco4-play
Do it like you mean it
bronco4-play's Avatar
You may not have had the bearing races seated all the way the first time. When you drove it they seated and made the nut loose.
bronco4-play is offline   Reply With Quote
Old March 16th, 2008, 11:25 PM   #13
Mclovin
"The Situation"
Mclovin's Avatar
what's a barring ? ive worked on cars for about 2 yrs in shops got some state certs and never seen a barring ?
Old March 17th, 2008, 07:13 AM   #14
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
with mine i usually check after a couple hundred miles and it usually needs a little adjustment, must be the 36's
broncobuddha is offline   Reply With Quote
Old March 17th, 2008, 07:34 AM   #15
jimhri
jimhri's Avatar
it's a BEARING, not a barring. this should not be a spell check item if you're old enough to drive.
btw, when you become a cook, are you going to open your own place, perhaps The RoadKill Cafe? as an off-roader, you could supply your own meat for fixin's like Flat Cat Stew, Dead Deer with Dumplings, Rack of Racoon, Center Line Skunk, Rigor Mortis Tortise, etc.
jimhri is offline   Reply With Quote
Page generated in 0.26693 seconds with 68 queries
