Just Empty Every Pocket - The Project - IT LIVES!! - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 26th, 2011, 04:11 PM   #161
Freak
Wheelin the HD
Freak's Avatar
Hmmm. . . So will we be looking for thos thing on the road any time soon?
Old August 26th, 2011, 04:18 PM   #162
jbsjunk
Little Member
jbsjunk's Avatar
Before snow flies or sooner. If all goes well next week, I'll see if I can't borrow one of the boss' dealer plates for a few days.
Old August 26th, 2011, 05:53 PM   #163
jhnyquest
goof ball
jhnyquest's Avatar
Get busy. We want progress pics mister.
Old August 26th, 2011, 06:13 PM   #164
jbsjunk
Little Member
jbsjunk's Avatar
You didn't say please.
Old August 26th, 2011, 06:20 PM   #165
jhnyquest
goof ball
jhnyquest's Avatar
Please.
Old August 26th, 2011, 06:21 PM   #166
jbsjunk
Little Member
jbsjunk's Avatar
It's under lockdown til Monday, then all hell breaks loose.
Old August 26th, 2011, 07:04 PM   #167
jhnyquest
goof ball
jhnyquest's Avatar
Ok
Old August 26th, 2011, 07:21 PM   #168
Freak
Wheelin the HD
Freak's Avatar
Pics or it won't happen.
Old August 29th, 2011, 03:20 PM   #169
jbsjunk
Little Member
jbsjunk's Avatar
Reworked drivers downpipe, much better but I'll still need a lift and adjust bumpstops.
Fixed trans leak.
New acc pump on carb, old gasket was leaking.
Moved the fork on the disco, now the axle is always connected.
Checked/filled fluids on everything down under.
The bad:
Took it for a ride and the trans slips like a mother. My fault for using a used trans as is.
So, I need to find money for the lift and to get the trans reworked. This pile will never see the road..............
Old August 29th, 2011, 07:02 PM   #170
jhnyquest
goof ball
jhnyquest's Avatar
What trans you have in it?
Old August 29th, 2011, 07:03 PM   #171
jbsjunk
Little Member
jbsjunk's Avatar
700r4. I have a couple ideas but I'm thinking the trans needs help. I am thinking of putting a 350 in it. We'll see.
Old August 29th, 2011, 07:09 PM   #172
Freak
Wheelin the HD
Freak's Avatar
U sure its full? I guess those are not hard to redo...
Old August 29th, 2011, 07:13 PM   #173
jbsjunk
Little Member
jbsjunk's Avatar
That's one of the things I want to check. I topped it off today but if stuff settled then who knows. I had the pan off to change the lockup solenoid a couple months ago and didn't see anything odd in the pan.
Old August 29th, 2011, 07:21 PM   #174
curbdog17
Mini Van
curbdog17's Avatar
Put some of this shit in there
Fixes everything
Old August 29th, 2011, 07:30 PM   #175
jbsjunk
Little Member
jbsjunk's Avatar
Last time I tried that stuff I had the trots for a week..........
Old August 29th, 2011, 07:41 PM   #176
Freak
Wheelin the HD
Freak's Avatar
I figured it would be a dumb question but if you've been messing with stuff its not hard to miss
Old August 30th, 2011, 01:14 PM   #177
jbsjunk
Little Member
jbsjunk's Avatar
Checked it today and it was a fuzz low. Dumped a quart in and took it for a spin. If you go easy it hooks, if you get on it it'll slip. Like driving with a bad clutch.
Any one with a buildable S-10 4x4 700r4?
Old August 30th, 2011, 03:11 PM   #178
Freak
Wheelin the HD
Freak's Avatar
Talk to skif...
Why not build the one you have?
Any 700r4 will work, you just have to swap the extension housing.
Old August 31st, 2011, 08:16 AM   #179
creeping death
I'm that guy.
creeping death's Avatar
i'll keep an eye out for a trans for ya.
talk to
jjoz05
, transmissions what he does.
Old September 10th, 2011, 07:55 PM   #180
jbsjunk
Little Member
jbsjunk's Avatar
Lets see, waiting for the shaft kit from Advance for the turbo 350. Then the trans is getting rebuilt along with the new output shaft.
Torque converter. A bump over stock will be fine.
Get the SYE kit for the 231 I picked up and get it ready.
Lift.
New rear driveshaft to work with the new SYE t-case.
I've been fighting the temp gauge sender so I'm going to make the trans temp gauge do double duty. I have a extra sender for the gauge that I'll put a SPDT switch on it so I can flip between trans temp and coolant temp.
The speedo I have a few questions in to a couple places so I can have a working and accurate speedo. The stock is mechanical and I'll be abandoning it for electronic. Just need to sort out a couple things.
It may see the road yet this year. It already runs very nice and does move but not well. Loose ends and more crap to do. It's been a cheap project until now. I probably have $1500 in it but I'll spend that again doing everything now to finish it and be a dependable rig.
Oh well, it's only money.
Page generated in 0.41195 seconds with 85 queries
