Just Empty Every Pocket - The Project - IT LIVES!! - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 2nd, 2010, 05:24 PM   #121
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
do you have a part number?
Bronco Ollie is offline   Reply With Quote
Old November 2nd, 2010, 05:48 PM   #122
jbsjunk
Little Member
jbsjunk's Avatar
http://www.summitracing.com/parts/MOR-39010/?rtype=10
Old February 17th, 2011, 08:12 AM   #123
musil
musil's Avatar
No updates? i'm on version two of my sbc xj swap, i went with the old school motor like you guys the first time and the performance increase was awesome but the faults of the carb finally got to me, so we are getting ready to transplant a 96 LT1, should be even more impressive now!
musil is offline   Reply With Quote
Old February 17th, 2011, 08:27 AM   #124
jbsjunk
Little Member
jbsjunk's Avatar
It's in hibernation mode. Just need to build the exhaust and a few minor things. It's not on my priority list at the moment.
Wouldn't mind a LT1 except for the front mount distributor.
Old April 5th, 2011, 03:31 PM   #125
jbsjunk
Little Member
jbsjunk's Avatar
THE BITCH LIVES!!!
Ran it for a hour or so making sure everything was filled up and working right. Jacked the rear up and let it run in gear to move things around. Drove it forward and back a couple times, didn't feel like moving a couple cars to get it outside but it did move under it's own power.
Took the wheel I got to match the rest to the sandblaster then painted it black. I scored a new tire that matches what I have on there now and those will go in place of the donut spare.
Just need to build the exhaust and put the front receiver on.............
Old May 6th, 2011, 05:58 PM   #126
cmarr6
Default Been awhile
Hey man, it's been awhile. Been watching your build JBS. Sounds like you have it close to road ready. Mine is close too. I need to build the exhaust, make a t-case linkage and I am in the process of hooking up an electic fan. Found a fan from a ford probe that fits great. I just cant figure out how to hook it up. I have tried every different combination of wiring but cant get the fan to run. The guy at the parts yard hooked it up to show me that it worked, but I did'nt see how he hooked it up. It has three prongs coming out of the conector. Can someone expain how I should wire this thing. Thanks
cmarr6 is offline   Reply With Quote
Old May 6th, 2011, 06:25 PM   #127
jbsjunk
Little Member
jbsjunk's Avatar
On the fan, if it's anything like the Taurus fan on my S-10 which is 3 wire one is ground and the other two were fan speeds; low-hi. The wires may ave a stripe or something on them to tell what goes where. Could look at a wiring diagram to see too.
I did drive the Heep around the lot last week, it drove and it stopped. It's a start.
Still have a list of crap to wrap up but after wrenching on everyone else's toys all day I don't even want to look at mine.
Old May 6th, 2011, 07:50 PM   #128
jhnyquest
goof ball
jhnyquest's Avatar
Awe come on your to close.
Old May 6th, 2011, 08:15 PM   #129
jbsjunk
Little Member
jbsjunk's Avatar
I'm waiting on some down time at work so I can do 3 weeks worth of cussing in a day on the rack there. I detest creepers and am spoiled with the hoists at work. It'll make building the exhaust much nicer. I can see things and routing then plan better than doing it on my back and screwing it up. I can get all my undercar stuff done then.
I'm in no hurry.
Old May 6th, 2011, 11:19 PM   #130
MiNi Beast
MiNi Beast's Avatar
Good to here it still moves, moves as slow as you perhaps, ready to let it loose sometime soon?
Old May 7th, 2011, 06:32 AM   #131
jbsjunk
Little Member
jbsjunk's Avatar
Me n Creepy are racing. First one done has to listen to Bieber.
Old May 7th, 2011, 06:57 AM   #132
Freak
Wheelin the HD
Freak's Avatar
You vs creepy is like watching a slow semi pass a slower semi...
Old May 7th, 2011, 06:58 PM   #133
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
RDK_YJ88 likes this...
Old June 17th, 2011, 05:27 PM   #134
jbsjunk
Little Member
jbsjunk's Avatar
Progress report. I put the new gate struts in, it now goes up and stays there.
*Sigh.............*
Old June 17th, 2011, 07:13 PM   #135
jhnyquest
goof ball
jhnyquest's Avatar
So what's left on the to do list?
Old June 17th, 2011, 07:41 PM   #136
jbsjunk
Little Member
jbsjunk's Avatar
1- Build exhaust.
2- Install front receiver.
3- Freshen up the carb.
4- Swap the new JK rear shocks in.
5- Change the trans filter/gasket and put a new lock up solenoid in and wire it.
6- A few piddly things.
Give me a day with it at work and it should be set. Been busy and no down time, may take a vacation day to do this.
Old June 17th, 2011, 07:53 PM   #137
curbdog17
Mini Van
curbdog17's Avatar
Sounds like you may be out and about before too long
Old June 17th, 2011, 07:56 PM   #138
jbsjunk
Little Member
jbsjunk's Avatar
Give it a few months. The exhaust has been on the build list for a year or so now. I've had the parts for a year. Hopefully before snow flies, this year. Been saying that for 3 years now.
Old June 17th, 2011, 08:13 PM   #139
creeping death
I'm that guy.
creeping death's Avatar
Give it a few months. Hopefully before snow flies, this year. Been saying that for 3 years now.
this all sounds too familiar.
glad to hear it's going. pix of it out of the garage or it didn't happen.
Old June 17th, 2011, 08:26 PM   #140
jbsjunk
Little Member
jbsjunk's Avatar
From a year or so ago. You didn't say it had to be current.
Page generated in 0.56191 seconds with 84 queries
