Just Empty Every Pocket - The Project - IT LIVES!! - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 15th, 2009, 12:58 PM   #41
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Originally Posted by Flexin' XJ View Post
Updates? How's the build coming?
x2
Old July 15th, 2009, 04:39 PM   #42
jbsjunk
Little Member
jbsjunk's Avatar
I did change the hood pins to a Moroso captured clip style I've used alot before. Less crap to loose. I also got the recovery jug mounted, just need to plumb it. Pics will come soon.
Just waiting on available funds to get the driveshafts made and build the exhaust. That is about it for now. I also need to put rear brakes on it, there is nothing left of the shoes.
Now, if someone wanted to sponsor my rig..................
Old July 22nd, 2009, 04:47 PM   #43
jbsjunk
Little Member
jbsjunk's Avatar
Here are some pics of the new goodies.
Hood pin clipped
Unclipped. Nothing to lose.
The new recovery jug.
I'm thinking seriously about getting street rod headers, got the number and dimensions already because I don't think my valve cover gaskets will last long where the manifolds are. Might be 1/8" gap between the two. Both sides have the same gap. I only want to build my exhaust once.
Old July 22nd, 2009, 09:05 PM   #44
Flexin' XJ
Flexin' XJ's Avatar
Didn't factory gm motors that came with those manifolds have that same gap? Did they have problems with the gaskets too? Is there some sort of heat shield you could fab up that would fit between there and attach to the valve cover bolts to direct the heat away instead of spending the money on headers? Not that there is anything wrong with headers.
Flexin' XJ is offline   Reply With Quote
Old July 22nd, 2009, 09:18 PM   #45
jbsjunk
Little Member
jbsjunk's Avatar
On the engines this type of manifold is from, the valve cover rails are closer to the deck than the TBI centerbolt heads I'm running. These are approx 1/2" taller than the old style heads. I've thought about a 1/4" spacer to pull them away from the heads but then I'll have problems running exhaust with the dump being in the frame rail.
I'll figure something out.
Old July 23rd, 2009, 12:35 PM   #46
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
get the manifolds ceramic coated
Old July 24th, 2009, 09:01 PM   #47
nosights
nosights's Avatar
Seen this jeep in person (while checking out Todds junk...sorry "sir"). Looks nice and clean, great install and a perfect shoe horn fit!
The bowtie is a sacraligious emblem though. You should really not advertise the GM parts under the hood! I am waiting to see if the old girl regects the heart transplant!
nosights is offline   Reply With Quote
Old July 24th, 2009, 11:36 PM   #48
jbsjunk
Little Member
jbsjunk's Avatar
A little sacraledge is good. You should hear the BMW crowd cry when they see a E30 with a Chevy in it. The bowtie may stay, hard telling.
*Snicker*
Old November 7th, 2009, 02:15 PM   #49
jbsjunk
Little Member
jbsjunk's Avatar
Haven't done much lately, but I did do a couple things.
Hood struts, they work beautify.
They open the hood further than with the prop rod and hold it open a foot if need be.
Had a set of mid 80's truck manifolds laying around and decided to fit them. Alot better clearance and should make building exhaust a bit better.
I haven't done the pass side yet because I need to pull the trans cooler lines and fab new ones because the outlet on the new manifold dumps where the cooler lines currently are, but once that is done I'll get pics of that.
Slow going now. Still need to come up with the funds for driveshafts, want those in before the exhaust gets done so clearances are right, at least the front.
Old November 7th, 2009, 07:39 PM   #50
drew91xj
drew91xj's Avatar
looks great.... my buddys have been trying to talk me into this swap also but just not sure, will probly build a stroker instead
Old November 7th, 2009, 07:41 PM   #51
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
Send a message via AIM to Xj Wheeler
lol holy crap thats some purdy interior
Xj Wheeler is offline   Reply With Quote
Old November 8th, 2009, 12:35 AM   #52
jbsjunk
Little Member
jbsjunk's Avatar
I call it the "Brady Bunch" option.
Old December 29th, 2009, 07:04 AM   #53
greygoose
I'm the dude
greygoose's Avatar
Any more updates?
Old December 29th, 2009, 07:13 AM   #54
jbsjunk
Little Member
jbsjunk's Avatar
The truck manifolds won't work, the pass side won't agree with anything. Looks like I'll be getting the Hedmans once tax checks are rolling. I did get a front skid and have that half assed installed. I need to rework where it mounts in the front because my rad also uses those mount holes.
It's not like I'm in a hurry..........
Old December 29th, 2009, 07:31 AM   #55
greygoose
I'm the dude
greygoose's Avatar
I guess not.
Old January 1st, 2010, 08:11 AM   #56
jhnyquest
goof ball
jhnyquest's Avatar
Man that thing looks good. Keep up the good work.
Old January 28th, 2010, 03:56 PM   #57
jbsjunk
Little Member
jbsjunk's Avatar
I got my Fed Tax check a few days ago so I'm getting the driveshafts done and I'm getting Hedman shortie headers so I can start working on the exhaust.
Yay for me.
I think I'm still well under $1000.00 for the Jeep and everything this far. I think the headers and shafts will put me to that. When I decide to put a good lift under it, then it will get expensive.
Old January 28th, 2010, 04:04 PM   #58
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
You need to get a lift under it before buying those driveshafts, why change them again afterwards?
RIP FULLSIZE4LIFE
Old January 28th, 2010, 04:22 PM   #59
creeping death
I'm that guy.
creeping death's Avatar
x2 i'm kicking myself in the ass for that one myself.
the build is looking sweet, keep us updated!!
Old January 28th, 2010, 04:29 PM   #60
jbsjunk
Little Member
jbsjunk's Avatar
Any kind of lift is a year or so away anyway and I wanted some drive time with it to work out bugs and tweak things until all is well. Then I'll go apeshit with a lift.
I'm going to eventually swap a different rear for it and possibly a front, but once it's first form is done, it'll be a driver. After that, who knows.
Page generated in 0.47124 seconds with 84 queries
