Just Empty Every Pocket - The Project - IT LIVES!! - Page 12 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 22nd, 2012, 08:49 PM   #221
jbsjunk
Little Member
jbsjunk's Avatar
Originally Posted by judgemikdredd View Post
pics or it doesnt count
I guess it don't count then.
Old August 25th, 2012, 12:21 PM   #222
jbsjunk
Little Member
jbsjunk's Avatar
Here's the long awaited pics.
Shiny new coils and shocks.
Shiny new leafs and shocks.
The holy grail for the speedo. Found the housing and gear on fleabay. The gear will be close from the charts I seen but at least it gives me a starting point.
My current speedo.
Now I can pick at things until I get sick of picking and just drive it.
Old August 25th, 2012, 04:59 PM   #223
jhnyquest
goof ball
jhnyquest's Avatar
Looks great.
Old August 30th, 2012, 07:55 PM   #224
jbsjunk
Little Member
jbsjunk's Avatar
Took it on another ride today. After driving it the first time and the epic vibration coming from the middle was telling me things weren't happy.
Pulled the front shaft to eliminate that part of it. Still has vibes but nowhere near what it did before. Then I took it on a 10 mile drive to see how things would act. Still vibes and I found a few things that can use attention.
The electric fan I put on has nowhere near the pull it should. The temp gauge took a dive so it was a guessing game. I'm thinking the trans cooler needs to be moved because it's blocking much of the radiator.
The rear pinion seal decided to start leaking. Good thing I was at my shop by then.
As for the vibes, even though I have the SYE in it I thought about putting the t-case drop in and see if that helps. My problem with that is the distributor is close to the firewall as it is and don't see trying to cut/bend/bash to gain clearance. I can get a new dist with an external coil which is about half the size of the current HEI.
Pinion angles look good at the diff and t-case. I thought about pulling the rear shaft and bring both to the driveshaft shop to see if the balance is off.
I'm thinking out loud to see if anything makes sense.
Old August 30th, 2012, 08:10 PM   #225
MiNi Beast
MiNi Beast's Avatar
tires dont have flat spots from sitting so long do they?
looks good. and yes all down to the finessing of it now. Id check the driveshafts first as with having the sye you shouldnt need the tcase drop. maybe need to rebalence with all that extra hp in it now.
Old August 30th, 2012, 08:20 PM   #226
jbsjunk
Little Member
jbsjunk's Avatar
Heh, didn't think about the tires. Anything is possible now. Got vibes from around 45 to 65 mph with just the rear shaft which is tire balance zone.
Old August 30th, 2012, 08:21 PM   #227
curbdog17
Mini Van
curbdog17's Avatar
Looks good, let s go wheeling.
Old August 30th, 2012, 08:24 PM   #228
jbsjunk
Little Member
jbsjunk's Avatar
It needs better gears than the current 4:10's. No OD gets the engine cranky at speed. Reminds me of driving one of my street/strip cars.
Old August 30th, 2012, 08:24 PM   #229
Freak
Wheelin the HD
Freak's Avatar
congrats on finally getting it to move.
Old October 29th, 2012, 06:06 PM   #230
jbsjunk
Little Member
jbsjunk's Avatar
Pulled the t-case today to fix a leak at the adapter. Did that, put the new speedo gear and housing in then put the new (To me) wheels/tires together. Figured out why it was leaking ATF. The new dipstick was mis-marked and the trans was over full letting it pool up by the adapter and leak there. Put a new pinion seal in the rear diff, the other was shot and leaking.
Took it for a drive after everything was done, the vibe I had is now gone, the speedo is +5 mph according to the GPS which is fine, I know it's close. It's 3000 rpm at 60 mph which I can live with so nothing will happen with the gearing for now. I didn't put the front driveshaft in yet so if there was a vibe, I could isolate it. If I still have vibes in the front once I get the shaft in, I want to get a posi-lock for the front diff so I can engage/disengage it when 4x4 is on.
The new wheels bring the sexy. Thanks to Greasy for letting me steal them. 16x8 Moabs with 265-75-16 tires.
The plug shot.
The gauges. I'm not entirely happy with the location but I can see them easy. So far, the temp is staying in check after I found what t-stat I put in it.
It's even closer now. Does this mean I get to go backwards now?
Old October 30th, 2012, 01:18 AM   #231
Ajhawk
Ajhawk's Avatar
im a fan, i have an 89 xj, currently have the motor and trans pulled, debating on rather to put the other 4.0 i have in it, or swap out the tranny, t case, and put the 350 we have sitting out back in it, but i do like how this turned out.
Ajhawk is offline   Reply With Quote
Old October 30th, 2012, 05:39 AM   #232
curbdog17
Mini Van
curbdog17's Avatar
The Moabs look sweet on there.
I think the ass needs about 1 more inch of lift.
Old October 30th, 2012, 08:24 AM   #233
jbsjunk
Little Member
jbsjunk's Avatar
It's just parked weird. It's actually a fuzz hi in the rear. I think the wheels make it. It's out of the trailer park and into the suburbs.
Old November 3rd, 2012, 12:46 PM   #234
jbsjunk
Little Member
jbsjunk's Avatar
Put the front driveshaft in it today and drove it a few miles to the gas station. No more vibes other than the tires.
Now I can nit pick things.
Old November 3rd, 2012, 12:52 PM   #235
creeping death
I'm that guy.
creeping death's Avatar
it's sexy! nice work jeff.
now we need pix of you burning the rear tires off of it......
Old November 17th, 2012, 02:05 PM   #236
jbsjunk
Little Member
jbsjunk's Avatar
Just scored a almost new set of Goodyear Authority AT tires from a friend that said they were too loud for him. Just the size I wanted too. I'll get them and glue 'em on in a couple weeks.
Old December 11th, 2012, 09:35 PM   #237
jbsjunk
Little Member
jbsjunk's Avatar
The tires have been in a holding pattern for the last 3 weeks until the day comes that the guy pulls his thumb out of his ass and gets them off his truck.
I did a couple things in the mean time. In my quest for a working horn I did everything aside from running new wiring for it. I happened to be looking at the owners manual for fuse locations for it when I ran across something in there that the key needs to be on for it to work. I tried and alas, it works! The key needs to be on for the horn to work?!?
I also worked and lubed the rear lock and latch trying to get the lock to work. I figured that out too. It was never used as the power locks work that too. It does work fine but I want to be able to lock/unlock the gate so the lock cylinder will come out and either be replaced or get fixed.
I have a few more things to pick at since there isn't money to get it legal yet.
Old December 11th, 2012, 09:56 PM   #238
srlbotanical
Because I Said So...
srlbotanical's Avatar
I really like this Jeep!
srlbotanical is offline   Reply With Quote
Old December 11th, 2012, 10:30 PM   #239
jbsjunk
Little Member
jbsjunk's Avatar
One thing I forgot about was that I scored a nice set of vent windows so I can get rid of the useless pieces of glass taking up residence in the front doors.
Film at 11.
Old December 12th, 2012, 07:39 AM   #240
GREASYHANDS
GREASYHANDS's Avatar
Looking good
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Page generated in 0.56085 seconds with 84 queries
