92 S-10 Blazer SAS - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2008, 07:05 PM   #1
zuds
Work in progress!!!
zuds's Avatar
Default 92 S-10 Blazer SAS
Here is a few pics of what I've been building over the last month or so. Only have a few pics downloaded so far. Let me know what you think!!!:chiefwoohaw::chiefwoohaw: or It has a D30 and a D35 for now with either a 327 or 350 and T-350 with S-10 transfer case with Advanced Adapters kit. 33x12.50 TSL radials on 15x10 Eagle 589 wheels. 4 inch CJ front spring pack with spring over conversion. Rear is stock S-leaves with spring over and full size Chevy 2 inch add-a-leaf and 4 in block( need custom leaf pack, block has to go, just there for mock up.) As it sits I either need bigger tires or drop it a few inches. But it does look good standing next to it.
zuds is offline   Reply With Quote
Old March 15th, 2008, 07:09 PM   #2
Toivo
Feel lucky?
Toivo's Avatar
less body lift, bigger tires!
other than that looks nice and clean.
Old March 15th, 2008, 07:11 PM   #3
zuds
Work in progress!!!
zuds's Avatar
There is no body lift. 4 inch Jeep leaf springs and spring over with 33's. I think I may need bigger tires. It also has the Jeep axles for now.
Last edited by zuds; March 15th, 2008 at 07:17 PM. Reason: Forgot to add something
Old March 15th, 2008, 08:39 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
Last month or so? I know the truth.
That would be true if it were just labor, but you also have months of research in this also.
Old March 15th, 2008, 08:48 PM   #5
zuds
Work in progress!!!
zuds's Avatar
Months?? You mean years of wanting to do it, then months of getting things ready for it. Now I finally did something about it.
Old March 15th, 2008, 08:53 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
True. Now shut up and get to work.
BTW, just noticed my Jeep in your avi.
Old March 16th, 2008, 02:45 AM   #7
TBSdontstop
TBSdontstop's Avatar
Looks good. Thats what I want to do to my blazer when I can afford it.
Are you working on it at the shop next to where jbsjunk work? If so I am the one that bought the red blazer that jeff had and saw this and yes its been more than a month since you started.
TBSdontstop is offline   Reply With Quote
Old March 16th, 2008, 08:09 AM   #8
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
Looks good!!! I have a set of dana 44 axles with 4.56 gears that would look good under that blazer and they should be the same bolt pattern that your wheels are.
CHEVYRCKS is offline   Reply With Quote
Old March 16th, 2008, 08:33 AM   #9
xj97sport
atv rider
xj97sport's Avatar
im wanting to do this to my 94 jimmy if you could send me a parts list (steering suspension) and the prper years or jeeps i can take the stuff out of ... thank you
Old March 16th, 2008, 11:33 AM   #10
zuds
Work in progress!!!
zuds's Avatar
Yes, thats the shop I'm in with JBsjunk. I finally started doing something on it a month or so ago.
Old March 16th, 2008, 11:35 AM   #11
zuds
Work in progress!!!
zuds's Avatar
Only problem with axles is I need drivers side drop on the front axle. Being that you have D44's its probably pass drop. If its a drivers drop let me know.
Old March 16th, 2008, 11:41 AM   #12
zuds
Work in progress!!!
zuds's Avatar
I'll put a list of parts together. I may end up having these axles and wheels available.
Old March 16th, 2008, 09:44 PM   #13
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
if it's a passenger drop you could use a full size transfer case behind the turbo 350 and go that way, or is there some other reason your stuck on the driver's drop?
71jeepster is offline   Reply With Quote
Old March 16th, 2008, 09:55 PM   #14
zuds
Work in progress!!!
zuds's Avatar
I just all ready have a trans and transfer case pretty much ready to go for the drivers drop. Not that its a major issue to get another one though.
Old March 16th, 2008, 10:11 PM   #15
71jeepster
71jeepster's Avatar
just a thought, that if you can get a deal on the 44's finding a passenger drop t-case would be easy to do.
Old March 18th, 2008, 04:38 PM   #16
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
how did you go about doing the front axle conversion. did you make your own crossmembers/brackets or did you buy them already made and if so where did you get them. very interested to know cuz i plan on a sas on my 95 S-10 one day. very nice build so far
Old March 19th, 2008, 01:59 AM   #17
rustycj5
Bump It Offroad
rustycj5's Avatar
Send a message via AIM to rustycj5 Send a message via Yahoo to rustycj5
Im in the process of doing this to an 85. What did you do with your steering after the SOA. Did you buy a kit or Modify yourself. If you could post some pics. Looks good!!
rustycj5 is offline   Reply With Quote
Old March 19th, 2008, 02:23 AM   #18
Motorcitydak
Merkin salesman
Motorcitydak's Avatar
Send a message via AIM to Motorcitydak
IMHO, its way to tall. CG is way up there. Keep it low with some good flex and a solid belly pan
Motorcitydak is offline   Reply With Quote
Old March 27th, 2008, 09:14 PM   #19
92comanche4x4
92comanche4x4's Avatar
i wanted to do a 4x4 swap and the sas in my 84 s10 blazer i did a 2.8-4.3 swap i traded that off for my comanche
LOOKS SWEET
92comanche4x4 is offline   Reply With Quote
Old April 26th, 2009, 11:38 AM   #20
zuds
Work in progress!!!
zuds's Avatar
Finally got back to it. I changed both axles and upgraded to a Dana 44 and 9 in with a spool and 4:10 gears on both ends. I got it rolling for now and had to quick put the front end on it to see what it would look like. It ended up being about 2 inches lower than it was with the other axle with all the changes. Also I have the steering done now.
Page generated in 0.31480 seconds with 83 queries
