tj d30 axleshaft in yj d30 axle. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2008, 12:27 AM   #1
Daniel
SFA Ranger
Daniel's Avatar
Default tj d30 axleshaft in yj d30 axle.
i just bought a 2000 tj axleshaft for my xj axle.
what all needs to be done to install it, i know a seal has to be installed, but what else needs to be done.
the yj axle has a c-clip and the tj axle doesn't.
Daniel is offline   Reply With Quote
Old March 15th, 2008, 12:28 AM   #2
Daniel
SFA Ranger
Daniel's Avatar
Old March 15th, 2008, 12:36 AM   #3
ddeadserious
ddeadserious's Avatar
http://stu-offroad.com/axle/yjd30con...jconvert-1.htm
If that doesn't help, PM Jeeperz Creeperz. There are some seal issues, he just took care of them when I had him regear my CAD XJ d30, which is the same design as the YJ one.
ddeadserious is offline   Reply With Quote
Old March 15th, 2008, 12:53 AM   #4
Daniel
SFA Ranger
Daniel's Avatar
ty sir.
i did a search on the forums and i couldn't find anything.
Old March 16th, 2008, 01:28 PM   #5
kickstand
circling the drain
kickstand's Avatar
Originally Posted by Daniel View Post
ty sir.
bullshit.
there is like a 3-5 page thread where monkeyevil and scorpio_vette discuss two very viable options for the passenger side tj shaft/seal issues when its put into a disconnect housing.
Old March 16th, 2008, 01:39 PM   #6
kickstand
circling the drain
kickstand's Avatar
http://www.greatlakes4x4.com/showthr...ight=axle+seal
Old March 16th, 2008, 03:55 PM   #7
Mudwolf
Cuz I Can
Mudwolf's Avatar
Installing the seals is definitely the most challenging part of the swap. I have a locker in the front on mine, with TJ shafts, and have no issues. I also took advantage of the timing and placed the greasible plugs at the ends of the axle shafts to function as an additional seal, and to keep all the crud out of the end of the axle tubes.
Mudwolf is offline   Reply With Quote
Old March 18th, 2008, 01:31 PM   #8
Theidt88
Boggers boy
Theidt88's Avatar
Send a message via AIM to Theidt88
I also second on mudwolfs comment. put outer seals to keep the mud out. after its done but the most difficult part is finding a place to come up with a seal. Measure the diameter of the housing tube and axle shaft, and call around to see if you can find a seal. Because its not machined like the driver side its a bitch, but possible just needs time and numbers. After that rip out the vacum disco and put a pull cable or something in there.
Theidt88 is offline   Reply With Quote
Page generated in 0.23427 seconds with 47 queries
