Spare Tire Plates! - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old March 13th, 2008, 10:24 PM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Thumbs up Spare Tire Plates!
These were designed with the idea of the most rigid mounting base in mind. Thats part of the reason we offer 2 instead of a 1 size fits all kind of plate.
The first one is for Jeeps and has both the 4.5" & 5.5" patterns, each has all five holes cut to the correct wheel stud size. You don't have to use them all but I thought the option may disuade theives a little when they have to remove 5 bolts rather than just a couple. The hole in the middle is to aid in centering the plate and then add a plug weld. They are 3/8" thick to help absorb vibration without metal fatigue.
The next is for the GM / Ford 8 lug and the Chevy / Toyota 6 lug pattern, Same plate with both patterns, only way to get at least 4 lugs for the bigger tires run on full size axles. Same 3/8" thick.....Check'em out when you get a chance, we are adding a couple of new sections to the website.....
[SIGPIC][/SIGPIC]
Dan Fredrickson
www.ruffstuffspecialties.com
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Thread Tools
Page generated in 0.16674 seconds with 26 queries
