dana 30 swap question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 13th, 2008, 08:12 AM   #1
JUSS10
4given4x4.com
JUSS10's Avatar
Default dana 30 swap question
so i am going to pickup a dana 30 that has the gear set in it to match the axles i swapped into the rear of my cj. this dana 30 I'm picking up just has the gears and the housing which leaves me with this question: is it easier to pull the gears and swap them into the axle thats already under my frame or is it easier to pull the knuckles off the axle under the frame and put them on the new axle i am picking up? to simplify, whats easier, gear swap or knuckles swap?
thanks
Justin
JUSS10 is offline   Reply With Quote
Old March 13th, 2008, 08:22 AM   #2
PavementPounder
PavementPounder's Avatar
If you do not know how to set up gears, do not pull the gears.
Swap the outers.
Old March 13th, 2008, 08:26 AM   #3
kickstand
circling the drain
kickstand's Avatar
Swap the outers.
x2
Old March 13th, 2008, 08:28 AM   #4
JUSS10
4given4x4.com
JUSS10's Avatar
thats what i was thinking. are the outers hard to swap?
Old March 13th, 2008, 08:37 AM   #5
kickstand
circling the drain
kickstand's Avatar
Shouldn't be.
I did this recently on a pile of Dana 30's from a YJ. So by your avatar I assume you have a cj.
All I did was remove the brakes, Tie-rods, remove the unit bearing and axleshaft as one, press out the ball joints, and then reassemble.
Old March 13th, 2008, 08:40 AM   #6
PavementPounder
Swapping outers = free.
Not knowing how to do gears = not free.
Therefore, you don't care how hard the knuckles are to swap.
(No, not hard. Should take like an hour or two depending on tools and working environment.)
Old March 13th, 2008, 08:40 AM   #7
JUSS10
4given4x4.com
JUSS10's Avatar
yeah i have a scrambler im building. thanks for the info it should help.
Old March 13th, 2008, 08:45 AM   #8
PavementPounder
Originally Posted by UP_ROKTOY View Post
Shouldn't be.
CJ's don't have unit bearings and you don't have to press out ball joints. You hit the knuckle with a hammer and it all falls off on your foot. No need to do anything with tie-rods, either. If you are doing this under the vehicle, you can leave the drag link attached at both ends, also.
Old March 13th, 2008, 08:59 AM   #9
kickstand
circling the drain
kickstand's Avatar
I understand Cj's don't have unit bearings, However I would replace the ball joints if I was he. I know the knuckle pops off with a hammer, but since you are there, and you are doing the swap why not at least make sure you have decent ball joints in it?
Old March 13th, 2008, 09:17 AM   #10
PavementPounder
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Because this guy was contemplating changing the gears as the primary approach to the situation. That means he was happy with the current condition of his outers, which suggests that there was nothing wrong with the ball joints currently in there.
It also makes the actual swap "not free".
Old March 13th, 2008, 09:20 AM   #11
kickstand
circling the drain
kickstand's Avatar
That doesn't mean he was happy with his outers, it means he "could" be happy with his outers.
Old March 13th, 2008, 09:44 AM   #12
PavementPounder
That's right. It means he is not unhappy with his outers.
I think you have a promising future as a Service Writer.
Old March 13th, 2008, 09:48 AM   #13
JUSS10
4given4x4.com
JUSS10's Avatar
are you guys set now? oh and the name is justin
Old March 13th, 2008, 09:50 AM   #14
kickstand
circling the drain
kickstand's Avatar
It doesn't mean ANYTHING as he did not mention the condition of his outers (Ball joints specifically) and how he felt about them.
I will go on a hunch here and venture a guess that when he begins this swap he will find at least one bad ball joint.
Old March 13th, 2008, 09:54 AM   #15
JUSS10
4given4x4.com
JUSS10's Avatar
well i rebuilt my axle shafts but you are correct in not having checked my ball joints. but to be on the other hand free is the idea here for the parts swap. you both have good points given the limited amount of information.
Old March 13th, 2008, 10:14 AM   #16
kickstand
circling the drain
kickstand's Avatar
PP and I would argue just for the sake of arguing even if we had all the information and told both of us you wanted to do it a completely different route
Old March 13th, 2008, 10:21 AM   #17
JUSS10
4given4x4.com
JUSS10's Avatar
fair enough. but seriously, thanks for the help guys
Page generated in 0.36520 seconds with 74 queries
