Ford 400 Carb Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 12th, 2008, 07:25 AM   #1
Dannyboy86
Dannyboy86's Avatar
Default Ford 400 Carb Help
Have a 79 F150 with the stock 400 and stock 2 barrel Mototrcraft carb on it. Thing runs great for about ten minutes before flooding. Gas starts comming out the overflow perge and everything. Seems like its a float problem not shutting of the fuel flow, but its not as far as i can tell. Took the carb apart several times, everything looks good and float and needle seem to work without flaw.
Please anybody else know what going on? Maybe a vac line is screwing shit up?
FYI the thing floods after ten minutes both when the float is started full of fuel or empty, huh wierd.
Dannyboy86 is offline   Reply With Quote
Old March 12th, 2008, 10:42 AM   #2
mooseracing
Stuck like a MoFo
mooseracing's Avatar
Send a message via AIM to mooseracing
Is the float sunk or in other words does it sink? I've gotten some very small pin holes and the only way to tell was to heat it up (not advising this) and see if any gas sprayed out.
Are you running a aftermarket fuel pump or a stock mechanical one?
mooseracing is offline   Reply With Quote
Old March 12th, 2008, 11:56 AM   #3
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
i had the same problem on my 79 bronco, everything looked ok but it kept flooding like you described, about 20 bucks for the parts to rebuild and a couple hours work fixed it right up
broncobuddha is offline   Reply With Quote
Old March 12th, 2008, 03:26 PM   #4
kkodet
kkodet's Avatar
Carefull with that. My 79s carb stuck open at 70mph. My brother was driving it down the freeway, and it continued to loose power till it stopped. By that time there was so much fuel in the oil it wiped out the motor.
Old March 12th, 2008, 06:28 PM   #5
broncobuddha
Starting over
yah i had to change the oil and filter right away on mine, it does nt take long to put alot of gas in the oil when that happens
Old March 12th, 2008, 07:00 PM   #6
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if you pop the top off the carb and the pull the needle valve out see if the tip is rubber. if it is use a magnifing glass to see if its cracked or split. they can and will and then when you stop it over flows the carb. I would have to check since I haven't set one up in 20 years, but the float height used to be around 5/16"-3/8" (depending on the carb) from the rim of the float bowl. if you can push down the float and it comes back up on its own then it should be fine. the other thing to check is fuel pressure. if your over about 8-9 psi then it will push past the float. should be around 6-7 max.
Yetti
Old March 20th, 2008, 11:00 AM   #7
Dannyboy86
Dannyboy86's Avatar
Thanks for the help guys
A $20 rebuild kit fixed my problems
Still didn't see anything unusual when i was rebuilding it thou
Old March 20th, 2008, 11:35 AM   #8
broncobuddha
Starting over
i didnt on mine either, everything even the needle and seat looked fine, but it sure worked better afterward
Old March 20th, 2008, 12:24 PM   #9
fsumotorhead
N8KVB
fsumotorhead's Avatar
http://home.earthlink.net/~bubbaf250/index.html
Page generated in 0.26236 seconds with 50 queries
