Ford 9 inch disc brakes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 11th, 2008, 08:12 AM   #1
t buff
t buff's Avatar
Default Ford 9 inch disc brakes
Has anyone put disc brakes on a ford 9 inch before without spending a lot of cash . Found a few things on the net but nothing is 100% Looking for ideas.
t buff is offline   Reply With Quote
Old March 11th, 2008, 09:45 AM   #2
Sandals
Fucking Zen as Shit
Sandals's Avatar
not a 9" but D35's, D44's, D60 and 4 bolts.
Should be able to find a rotor with the right lug pattern that will fit on,
Find a caliper that fit that rotor with ease. I prefer Chevy stuff as it's
easy to get, cheap and the way it mounts make it simple.
Then either build or buy a bolt on, or weld on caliper bracket.
Assemble and plumb
Old March 11th, 2008, 11:15 AM   #3
Yup, I've done it about 3 times. Chevy 1/2 ton calipers, Ford 1/2 ton front rotors and brackets from Stock Car products.The rotor mounts on the inside of the flange with the rotor facing inward. You can get longer studs from CarQuest. Rough numbers:
Calipers $30 each $60
Rotors $40 each $80
Brackets $20 for the set $20
Studs $2.50 each $25
Approximate total: $185
Old March 11th, 2008, 11:50 AM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I did. I have pics if needed!!
I used 78 chevey k10 front calipers, 79 ford F-150 rotors, Brackets were bought from www.speedwaymotors.com . I would provide the direct link to the brackets but it seems their site is not working???
Old March 11th, 2008, 12:24 PM   #5
Only difference between what I did and Plato2k5 did was he mounted the rotors on the outside of the flange where I mounted mine on the inside. Upside to what he did is that the rotors can come on and off without pulling the axles. Upside to what I did was to get more clearance between the caliper and inside of the wheel. I liked that because it was easier to power wash out the brakes.
If you do a test assembly both ways you will be able to determine which way you like it.
Old March 11th, 2008, 01:20 PM   #6
Strangler
Strangler's Avatar
Very tempted to turn this into a sig....... AMC guy.
Old March 11th, 2008, 01:40 PM   #7
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
The k10 calipers are very nice. Just two sliding pins to pull and off it comes. There is no E-brake hookup.
Old March 11th, 2008, 02:02 PM   #8
Bossman63
Two Trackers 4x4 Member
Bossman63's Avatar
I put disc on my 72 Bronco Front & Rear. For the Ford 9" I bought the kit from Jeff's Bronco Graveyard ($295), it bolts on. Took me about 30 minutes a side to change. Need to buy G.M. single piston calipers (get them loaded) and they will have the pads too. If you want the e-brake, buy rear calipers from a 79-85 El Dorado, Riviera, or Tornado. I believe I have about $375 into my 9" axle, but it stops on a dime with 35" tires.
Two Trackers Four Wheel Drive Club Member
Bossman63 is offline   Reply With Quote
Old March 11th, 2008, 02:15 PM   #9
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
do they tell you what rotors you need though? Sure you can buy kits out there but they require you to buy THEIR rotors.... which cost a good amount of change when they need to be replaced.
I love how mine stops.
I also swaped my master cylinder out and added a prop. valve to adjust the rear line pressure. I can stop when i need to on 35" tires as well :)
Old March 11th, 2008, 03:18 PM   #10
What master cylinder did you use?
Old March 11th, 2008, 07:21 PM   #11
t buff
t buff's Avatar
thanks for the help guys with all the help i figured it out
Old March 11th, 2008, 08:19 PM   #12
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
check out steeltech solutions. thats where I got my conversion for my scout II 44
Old March 11th, 2008, 08:54 PM   #13
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
i'm trying to remember but can't for the life of me
I beleive its from a ford with hydraboost. Mabey i can find a number stamped on it and run it somtime to find out???
Old March 11th, 2008, 11:05 PM   #14
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Here's how I did it.
http://www.greatlakes4x4.com/showthread.php?t=31308
JohnnyJ is online now   Reply With Quote
Old March 14th, 2008, 02:51 PM   #15
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Chevy half-ton calipers, Chevy half-ton rotors, weld on brackets.
(running Chevy 6x5.5 bolt pattern on my 9").
Also swapped out master cylinder (manual brakes) and it stops 37's like putting it in reverse
Old March 14th, 2008, 03:13 PM   #16
What master cylinder?
Old March 14th, 2008, 03:18 PM   #17
Jeeperz Creeperz
GL 4x4 Vendors
You keep asking that....
Old March 14th, 2008, 04:52 PM   #18
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Mine is from a 78 G Marquis with hydro
Old March 14th, 2008, 06:06 PM   #19
thanks!
Old March 14th, 2008, 06:55 PM   #20
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
here is the valve i am using: http://www.jegs.com/i/JEGS/555/63020/10002/-1
Page generated in 0.37637 seconds with 83 queries
