97 F150 Misfre ??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2008, 05:19 PM   #1
skrebs
Default 97 F150 Misfre ???
hi guys,
I am trying to diagnose a misfire problem on my 97 f150. It had bad coils and I replaced those and while doing that I got new plugs and wires too. Now my problem is still around, however its only cylinders 4 and 8. Before it would be anyones guess to which cylinder would be the problem. I ran injector cleaner through it and no change. Any thoughts??
skrebs is offline   Reply With Quote
Old March 10th, 2008, 05:35 PM   #2
IDIeselman
IDIeselman's Avatar
Swap the plug wires to different cylinders and see if the miss follows. A friend of mine had the same problem and went through 3 sets of value craft plug wires on his truck untill I convinced him to buy a set from the stealership to cure it. If you still have your old set try running them on the offending cylinders.
Old March 10th, 2008, 07:08 PM   #3
masterbeatty
masterbeatty's Avatar
i aggree with idieselman my buddy has the 97 and had the same problem went through 2 packs, countless plugs an wires. finally got another set of wires and i dont know what was different but it fixed it.
Old March 10th, 2008, 07:13 PM   #4
blownexploder94
Todd
blownexploder94's Avatar
I have a 97 had the same problem it ended up being cyl 4 in the back on passenger side .... the little coolant tube that is right above it that factory clamp needs replaced this was an actuall fix that ford did was to cut it off an replace the clamp it will drip down in the spark plug hole an cause a mis fire i had to clean the hole all out after that and just did plugs and everything then
Old March 11th, 2008, 05:05 PM   #5
skrebs
is it easy to see that the clamp has gone bad?
Old March 11th, 2008, 05:09 PM   #6
blownexploder94
Todd
no not really atleast not for me its like 2 inches from the fire wall back there its not an adjustable clamp it was one of those crimp type from the factory ..... but there is a steel pipe that comes off the intake by that spark plug hole it comes up about 3 or 4 inches then turns about 90 degrees pointing directly towards the drivers side but right where rubber and metal meet are above the last hole
Old March 11th, 2008, 05:14 PM   #7
blownexploder94
Todd
mine didn;t leak alot at all. and could not really see it just noticed there was a lil tiny bit of coolant n the intake.. but my boss told me that he saw a few come in to the shop and ford said to change the clamp clean the hole an connection and go from there
Page generated in 0.19949 seconds with 44 queries
