changing brakes on Kaw mojave - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2008, 12:59 PM   #1
huntstoomuch
Always chasing a big rack
huntstoomuch's Avatar
Default changing brakes on Kaw mojave
Ok, so I guess I'm an idiot, I can't figure out how to push the piston back in on the rear caliper of a '99 Kawasaki Mojave 250 quad. Anyone know the trick? I've tried a c-clamp and turning it in like I've had to on cars before... no go.
huntstoomuch is offline   Reply With Quote
Old March 9th, 2008, 02:53 PM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
did you try taking the cap off the brake reservoir? There's not much room in the braking system for fluid, so maybe you're hydrolocking and that is keeping the piston from moving back in.
I've never worked on a quad- Motor Slut is your bet bet for an answer here.
@clarkstoncracker
Old March 9th, 2008, 08:37 PM   #3
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
What he said! Take the cap off and try again. Also make sure you are pushing the piston back in evenly, it will jam if you are only pushing on one edge. If that doesn't work then you must be doing something wrong or the piston is seized.
Old March 9th, 2008, 10:15 PM   #4
huntstoomuch
Thanks guys, I'll try taking the cap off tomorrow.
Page generated in 0.20710 seconds with 35 queries
