Dodge 44 & 9 3/4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2008, 08:59 AM   #1
TsCuda
TsCuda's Avatar
Default Dodge 44 & 9 3/4
I might be picking up a set of Dodge 44's and 9 1/4 belived to be out of a 78 RamCharger. Would this be a good idea to have them narrowed to fit a 79 CJ5 nt? If so who can I get to cut them down.
TsCuda is offline   Reply With Quote
Old March 9th, 2008, 02:34 PM   #2
TsCuda
TsCuda's Avatar
I ask about the Dodge axles because most all I see is about using the Fords.
Old March 9th, 2008, 06:12 PM   #3
PavementPounder
PavementPounder's Avatar
People usually don't use Ford axles in CJ's because the drop is wrong.
What width do you want to end up at? If you cut any axles all the way down to NT CJ, you'll be rubbing your tires on the front leafs at lock with 12.5" or more wide tires. The only way to avoid this is to run really low backspacing and if you're willing to do that, just run a wider axle with a normal wheel to take the stress off the wheel bearings. That and the work involved to cut down the axles will exceed the cost of just buying axles that are a better fit in the first place.
What width do you want to end up with? 58"-60"?
Old March 9th, 2008, 10:48 PM   #4
TsCuda
TsCuda's Avatar
The tires I have are 32x11.5 so I guess rubbing dont sound like an problem. And the Front D30 on it 58" I think. A 60" wide would only help in the steering dept. I'm getting the axles for free so I was just kicking the idea around right now.
Old March 10th, 2008, 05:20 AM   #5
PavementPounder
If the front is 58" wide, that would be a WT D30, which would be enough to keep your tires off the leaf springs.
Doesn't sound like they would be very "free" if they would require all that work and cost to swap in, especially if you'd then have to outboard your springs in the process of cutting down the axles. You probably could buy a set of factory D44's from another application from 58"-60", like from a Scout or Wagoneer, and be way ahead of the game.
Old March 10th, 2008, 02:58 PM   #6
smasheromalley
smasheromalley's Avatar
Werent some early ramchargers also fulltime? As in unit bearing type hubs?
Old March 10th, 2008, 03:24 PM   #7
PavementPounder
"Full-time" does not mean "unit bearing". It means the vehicle has drive flanges (no lockouts).
Old March 10th, 2008, 06:50 PM   #8
TsCuda
TsCuda's Avatar
Ok I'll go with it's a bad idea. Like I said was only kicking around that idea. I wont have the spare cash for a month or so but do you have any ready to go?
Old March 10th, 2008, 09:09 PM   #9
PavementPounder
The only set I have "ready to go" gets you 4.10's, a D44 rear, and a Detroit, but only a D30 front. Everything else I have would be good candidates but all would need to be built (but not cut).
If you're fine with staying at NT width, I have a D44 front housing that was cut down to NT width. Find yourself a DJ or intermediate CJ-5 D44 rear, and you'll be good. If you wanted, you could retube it to WT width and run an 86 CJ D44 rear or a Scout D44 rear with it. Anything else will require outboarding of your springs, a full-width kit (like the Poison Spyder kit I have) or other fabricating to move the diff over.
Deciding to outboard or buy a kit then opens doors to either Scout or Wagoneer D44's f/r that you would not have to cut down.
There are also 9" options for the rear, as the housings were narrower before 1970 or 72 (I forget). I have one of these sitting around, also.
Old March 17th, 2008, 06:08 PM   #10
smasheromalley
Maybe full time wasnt the best way to say it, but with that era dodge it could mean
Supposedly less desirable I think
Old March 17th, 2008, 06:13 PM   #11
PavementPounder
Originally Posted by smasheromalley View Post
Maybe full time wasn't the best way to say it, but with that era dodge it could mean
True. Unit bearings just make the front axle "live" (always turning when moving) unless you have a CAD or some other kind of vacuum disco.
Page generated in 0.30303 seconds with 56 queries
