The Little CJ that Could - ALIVE AGAIN (9/22/2012) - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 23rd, 2008, 09:23 PM   #21
Fraser
Fraser's Avatar
Originally Posted by ddeadserious View Post
Like just weld spots(like tack welds) every inch or so and jump around the edges of the sheet metal. It'll make it less likely to warp and burn holes through.
x2 or do a tack, let it cool off for a couple seconds and continuosly tack, linking them all together
Old March 30th, 2008, 03:49 PM   #22
joslovandikai
joslovandikai's Avatar
i came home yesterday to this:
the new KEVLAR windshield frame from Shell Valley Company. all the holes pre-cut/drilled for the wiper motor and assembly.
J.D.
joslovandikai is offline   Reply With Quote
Old March 30th, 2008, 07:05 PM   #23
89'xj
now known as 79'CJ7
Very nice
89'xj is offline   Reply With Quote
Old April 1st, 2008, 09:26 PM   #24
joslovandikai
got back out to the garage again...began fixing the passenger side...getting those fender flares off was a pain...and our wleder wasnt working right tonight so welding was a pain in the ass..
pics of recent progress:
both patches
yesterdays
tonights
closer of tonights
i know the welds arnt great but theyre gettign better as i go - that piece should be attached
the drivers side rear fender was holding parts of the body together
J.D.
Old April 3rd, 2008, 10:15 PM   #25
joslovandikai
started using the acytelene torch today and it made everything go much faster...we got both drivers side exterior panels welded on.
this made life so much easier
while welding up this piece we failed to notice the wiring harness that was burning on the inside until we had finished the weld...oops...luckily it only melted thru the tueb that holds htem all together.
and the other piece
this finishes up the exterior metal work..most all of this will be covered in fiberglass and then bedlined...the idea is that it stays in one piece until i graduate so my dad can begin his restoration dream.
J.D.
Old April 3rd, 2008, 11:01 PM   #26
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
driver side looks much better! lol
looks like a fun project
71jeepster is offline   Reply With Quote
Old April 4th, 2008, 06:47 AM   #27
joslovandikai
yah it does...we also rewelded the rear piece on the pass side with the torch...
J.D.
Old April 10th, 2008, 08:35 PM   #28
joslovandikai
sorry ive been a little busy lately..so heres an update of a coupel nights work...we fixed the floor wear the seatbelts attach..near the bottom of the roll bar...
before
after
passenger side
also started some final grinding on the exterior before bondo
J.D.
Old April 11th, 2008, 07:06 AM   #29
comanche38
comanche38's Avatar
Not the typical way to do bodywork...
comanche38 is offline   Reply With Quote
Old April 11th, 2008, 08:25 AM   #30
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
x2
but its better then rust and pop rivets, Keep up the good work
scramblerman72 is offline   Reply With Quote
Old April 12th, 2008, 04:40 PM   #31
Fraser
Fraser's Avatar
Originally Posted by scramblerman72 View Post
x2
X3 i believe that right there is called brazing
Old June 7th, 2008, 05:07 PM   #32
joslovandikai
sorry everyone...i havent updated this in a coupel of months...not a lot has happened just a lot of bondo and sanding and more bondo and more sanding...i have pics of all this but im jsut going to skip to the exciting stuff....we set out today to get her primed and ready for paint( hopefully tommorow but not likely)...and we accomplished this so i have a couple hours on my hands before we can start sanding the primer...so heres pics of (stage 1) almost finished.
Our high tech paint booth
my dad painting the hood
J.D.
Old June 7th, 2008, 05:18 PM   #33
capone
capone's Avatar
Looks Good
capone is offline   Reply With Quote
Old June 7th, 2008, 06:48 PM   #34
jthomp
jthomp's Avatar
I also learned the hard way to be aware of wires. I cut into the harness of my TJ on the upper driver side under the hood. Luckily the battery was out, so no permanent damage.
Keep up the good work.
jthomp is offline   Reply With Quote
Old June 7th, 2008, 08:09 PM   #35
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
You taped off everything but the frame. What's up with that? Nice progress.
Craig
Old June 7th, 2008, 09:03 PM   #36
mpsbvp
Hummer recovery team
mpsbvp's Avatar
Send a message via AIM to mpsbvp Send a message via Yahoo to mpsbvp
looks nice and babby blue lol
mpsbvp is offline   Reply With Quote
Old June 7th, 2008, 10:59 PM   #37
joslovandikai
not really sure why we didnt tape off the frame..i guess we werent really that worried about it....
weather looks good tomorow so as long as it stays that way we are spraying final paint tomorow..its gonna be black even though ive been told by a million people not to use black because it shows all the imperfections
J.D.
Old June 22nd, 2008, 03:15 AM   #38
Mclovin
"The Situation"
Mclovin's Avatar
well ??
Old June 22nd, 2008, 10:29 PM   #39
joslovandikai
Sorry for the long lapse since my last update...we did end up painting the next day (which just happened to be the day the big storm rolled through) lucky us we used urethane based paint and it was dry enough by the time the storm came through that the paint was not affected
Finished Product
Many problems have since come up though:
1st - Took it for a small test drive around the block and it was all over the road... A quick look turned up a broken drivers side shock mount so we got that fixed and at the same time replaced the front shock absorbers
2nd - The steering was still rediculously loose so we replaced the steering dampner but before we could get it on the road
3rd - we noticed we had no voltage and our alternator was shot - so we picked up a new alternator but they sold us the wrong one but it still fit so we could not understand what was wrong until my old man realized the alternator was functioning backwards thus not putting out voltage so we got the right alternator this time and that all works now but....
4th - the steering is still way too loose and she is at the shop right now being looked over.
J.D.
Old June 23rd, 2008, 09:46 AM   #40
JEEPR
Playing Possum
JEEPR's Avatar
It's how we used to do it years ago.
Looks good.
JEEPR is offline   Reply With Quote
Page generated in 0.56058 seconds with 83 queries
