sand rail - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 8th, 2008, 09:40 PM   #1
sandmaster
sandmaster's Avatar
Default sand rail
this sand rail is a blast to drive !!
im sure i ll miss a few of the goodies on this so if interested ask away
built 2180 with dual webers, all the right goodies to run very well and stay together. the case was machined at apple tree automotive at silver lake and all the parts for the build were put together by the previouse owener of apple tree (Larry Wagner). The short list of parts include a c/w stroked crank forged pistons with a compression ratio of 10.5 to 1 can be changed to 11.5 to one pretty easy. bug pack performance rods. 041 racing heads that were ported and polished ss vaulve performance springs retainers and keepers
webber dual carbs with hex bar hidden linkage tall 6 inch k and n filters and prefilters electric fuel pump w/ reg. eagle 135 cam melling high output/pressure oil pump, extra deep oil sump, external oil cooler and filter, chromoly 8 mm head studs with the extra mods needed to keep a enigne like this together.
the trans is a sand pro tran from california with 4.88 ring n pinion double snap ring super diff, double spiders on both sides , extra h/d side plates on both sides, ftc main shaft close ratio gears chromoly shift fork h/d three bolt nose cone. sway away forged long axle shafts kenady stage two clutch with a stage two clutch disc lightened fly wheel
cnc billet cross drilled rear disc brakes, 8 gallon spun aluminum fuel tank, jt aluminum front beam polished aluminum center councle with vdo gauges monitoring volts oil pressure oil temp amps and a belt warning light if the cooling belt breaks and the ignition switch .there is a 8k tach short throw shifter cnc chromed hyd peddel assembly hyd clutch set up peddels can be adjusted for difernt heigth drivers
front wheels are cms polished aluminum with smooties by sand tires unlimited
rear wheels are cms polished aliminum 15x15 with 13 plus paddles also by sand tires unlimited
the seats are poly racing seats not the cheap fiberglass ones with padded seat covers 5 point harness for both riders
this is a very fast very reliable sand rail !! the paint has a few chips from the dunes but looks very good still . the paint was painted at a body shop and is automotive paint so touchups ae very easy. any other questions i might have missed leet me know 5500.00
seems my pics are to big to post will try to make them smaller or pm your e mail address i ll send pics along
here is a pic that would post if you would like others i can e mail them
sandmaster is offline   Reply With Quote
Old March 9th, 2008, 11:05 AM   #2
L4CX
Out for the Summer!
L4CX's Avatar
Nice looking Rail. Willing to trade? I have a 96 Ford Explorer.
L4CX is offline   Reply With Quote
Old March 9th, 2008, 03:44 PM   #3
sandmaster
sandmaster's Avatar
pass on the explorer maybe a eary camaro as partial trade
Old March 9th, 2008, 04:18 PM   #4
CRAZYRED
Red Head, Green Jeep!!
CRAZYRED's Avatar
Sweet Rail! Good price!
BUMP
CRAZYRED is offline   Reply With Quote
Old March 9th, 2008, 04:40 PM   #5
1968scout800
6 jeeps 2 beat
1968scout800's Avatar
Send a message via AIM to 1968scout800
how about a jeep got a nice yj and what kinda frame?
1968scout800 is offline   Reply With Quote
Old March 9th, 2008, 05:10 PM   #6
sandmaster
sandmaster's Avatar
scout sent you a pm
Old March 9th, 2008, 10:00 PM   #7
kargod
Charcoal Mellowed
kargod's Avatar
You have a lot of amazing parts in your buggy. I just got rid of mine and am building another. Mine was almost the same color but had a lot more stock shit...
good luck with the sale - It took me 4 weeks to miss mine and buy another frame to build.
kargod is offline   Reply With Quote
Old March 11th, 2008, 09:29 PM   #8
sandmaster
sandmaster's Avatar
ttt
Old March 21st, 2008, 08:33 PM   #9
sandmaster
sandmaster's Avatar
ttt
Old March 23rd, 2008, 12:39 PM   #10
sandmaster
sandmaster's Avatar
ttt
Old April 13th, 2008, 12:29 AM   #11
sandmaster
sandmaster's Avatar
ttt dunes are awaiting
Old May 5th, 2008, 10:58 PM   #12
sandmaster
sandmaster's Avatar
ttt
Old May 14th, 2008, 11:25 PM   #13
sandmaster
sandmaster's Avatar
ttt
Old May 27th, 2008, 10:31 PM   #14
sandmaster
sandmaster's Avatar
ttt
Old August 15th, 2008, 01:00 AM   #15
sandmaster
sandmaster's Avatar
ttt last time
Page generated in 0.30410 seconds with 68 queries
