Ladder Bars - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 7th, 2008, 11:06 AM   #1
DirtyBert
not so newbie
DirtyBert's Avatar
Default Ladder Bars
I'm looking for some ladder bars that will work on a cj7 model 20 rear axle. I've invested too much money in the axles on my cj to change anything major this year. My 4 inch lift springs are so soft that I get so much axle rack that I can't keep the drive shaft in it.
DirtyBert is offline   Reply With Quote
Old March 7th, 2008, 11:15 AM   #2
OldSailor
AKA GreyShrink
OldSailor's Avatar
I assumeyou men "axle wrap", not axle rack. There are better solutions than ladder bars. There is a company (can't remember the name) that makes a shock absorber & bracket that attacked on top of the spring. It goes horizontalle between the axle u-bolts and the end of the spring near the main pivot bolt. However, I'm sure any decent fabricator could make the bracket, and you could take measurements and figure out which shock would work best. You could even get a 5-way adjustable shock and determine the best setting.
OldSailor is offline   Reply With Quote
Old March 7th, 2008, 11:26 AM   #3
PavementPounder
PavementPounder's Avatar
As in your slip is pulling apart, or you are damaging the shaft somehow?
Did you lift the CJ without lengthening the rear driveshaft?
Old March 13th, 2008, 04:54 PM   #4
DirtyBert
not so newbie
DirtyBert's Avatar
sorry about the brain fart, the "wrap" on my axle is about three inches each way when i let the clutch out with it sitting on flat ground. the shaft was built to measurment at a local drive line shop. i did find a 5th link setup through GL4X4 so thanks for your input and wish me luck this season.
Old March 13th, 2008, 05:28 PM   #5
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
One of the cj-7 that i am parting out has a set of ladder bars on it, i would sell them for $20 if you are interrested?
CHEVYRCKS is offline   Reply With Quote
Old March 13th, 2008, 05:52 PM   #6
BigTony
Rock Rebel
BigTony's Avatar
Your on the right track a 5th link is the way to go. Unless your bracket racing
BigTony is offline   Reply With Quote
Old March 14th, 2008, 07:30 AM   #7
mudbrat71
got mine at at farm store 3 piont hitch turn buckel have $60 and 1.5 hr time pinion dont move no more and still have good ride
can send pics of set up if you want
mudbrat71 is offline   Reply With Quote
Old March 14th, 2008, 10:16 AM   #8
DirtyBert
not so newbie
DirtyBert's Avatar
I would like to see a picture to see what the turn buckel setup looks like.
Old March 14th, 2008, 10:25 AM   #9
jeepnxj96
jeepnxj96's Avatar
it is pretty simple, all you would be doing in simple terms is mounting one 4-link bar from the frame to the axle,preferrably on top of the axle to prevent the wrap. my buddys cj has two of them
Old March 14th, 2008, 10:26 AM   #10
Mudwolf
Cuz I Can
Mudwolf's Avatar
Can you post pics on here? I'd like to see it, as well!
Mudwolf is offline   Reply With Quote
Old March 14th, 2008, 10:34 AM   #11
DirtyBert
not so newbie
DirtyBert's Avatar
I think this is going to be easier than I thought.
Page generated in 0.29772 seconds with 56 queries
