Trouble removing axle hub nut - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 28th, 2006, 08:00 PM   #1
Irishjeeper
Irishjeeper's Avatar
Default Trouble removing axle hub nut
Any ideas? I used a 24" pry bar and broke that and used a pipe, broke my 1/2 rachet. I don't have any torches or a strong enough air compressor. ?????????????????????????????????????????????????? ???????????
Irishjeeper is offline   Reply With Quote
Old March 28th, 2006, 08:09 PM   #2
boggin-machine
boggin-machine's Avatar
i always use air. but it may be rusted or seices on there tight. i got an old trick for you. mix som atf tranny fluid and keorasine 50/50. put it in a spray bottle and let it work its self into the thread. it will break the bolt loose. it works great the longer the better. then try it with a impact or a rachet.
Old March 28th, 2006, 09:30 PM   #3
Axles nuts are actaully not bad, here's a good trick:
To break ones like that loose, you need IMPACT, not static torque. So simply pushing/pulling on a long bar usually breaks it. This is why impact wrenches work well. They hit it with a high torque to break it loose, but the duration isn't enough for part failure(usually).
1) Get a good breaker bar.
2) Put it so the bar is on the nut, and positioned horizontal.
3) Put about a 4 foot piece of sturdy, close fitting pipe on it.
4) Get out a sledgehammer, a real one with a 3 foot handle, not a 4 lb handheld.
5) Hit the bar with all you're worth. Usually 2-3 hits and the nut is off.
It provides a huge amount of force, but not a long duration.
I broke a couple sockets popping the axle shaft nuts off my last honda when I was doing an engine swap. Was told of this method, and bam, came right off.
Old March 28th, 2006, 09:56 PM   #4
Noah's Ark
Noah's Ark's Avatar
Your air compressor should be enough. The impact wrench may not be doing the trick. You are free to borrow mine. I think it has about 600-750 ft lbs in reverse.
p.s. send me that pic on an e-mail!
Noah's Ark is offline   Reply With Quote
Old April 2nd, 2006, 07:36 PM   #5
C.K.
Dont Feed the Cyco
C.K.'s Avatar
If you are still working on it I have a torch you can use.
C.K. is offline   Reply With Quote
Old April 3rd, 2006, 03:59 PM   #6
Immortal
NO RELIGION WAT!
Immortal's Avatar
Same here.....I am just around the corner from you....I have impact and torches.
Page generated in 0.20994 seconds with 41 queries
