Using Square or rectangle tube for cage? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 6th, 2008, 12:43 AM   #1
Shotgun
I only wheel with boats.
Shotgun's Avatar
Default Using Square or rectangle tube for cage?
is it bad, I was thinking of using it to make a simple cage design in my blazer. I know it will take an impact I made a halo in my derby car and it held great.
any input is good input.
Old March 6th, 2008, 08:10 PM   #2
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
do it and show us pics. I dont think it would hurt anything but it might not look as good as tube but it might look really good.
Old March 6th, 2008, 08:28 PM   #3
badazzamc
Get Some
badazzamc's Avatar
might be hard to bend? I really dont know though
Old March 6th, 2008, 08:31 PM   #4
stevelknievel
Fuck Cancer
stevelknievel's Avatar
Send a message via AIM to stevelknievel
i wouldnt bend. just cut it at the right angles and weld it up
stevelknievel is offline   Reply With Quote
Old March 6th, 2008, 09:15 PM   #5
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
theres an i dea i never thought of 2 inch square tubing with 1/8 inch wall or 3/16would look pretty nice may be excessive and add a shit load of weight but i like the idea i may look into it as well Great idea Blaze
Old March 7th, 2008, 06:18 AM   #6
luvitmyjeep
broken
luvitmyjeep's Avatar
if you could some how bend it with the corners out like a diamond, it would look sweeeeeeeet!
luvitmyjeep is offline   Reply With Quote
Old March 7th, 2008, 06:24 AM   #7
tjs0461
tjs0461's Avatar
If you do that i would gusset or plate it (the corners that is) otherwise go for it
tjs0461 is offline   Reply With Quote
Old March 7th, 2008, 07:17 AM   #8
DieselMTU
DieselMTU's Avatar
I was thinking about the same thing, but my project is still a long ways off. Keep us updated.... I would like to see how it turns out.
DieselMTU is offline   Reply With Quote
Old March 7th, 2008, 08:49 AM   #9
roll-bar Bob
roll-bar Bob's Avatar
when a rig rolls on to a cage and then rolls over the loads move on the cage rotate around that bar as the rig rotates with tube the strength is uniform 360 around it, no mater where the load is applied Square will work better than nothing but round would work better
Old March 7th, 2008, 09:18 PM   #10
SNODOGG1
SNODOGG1's Avatar
I used 2" square for my bumpers,brushgaurd,rear tire carrier.... next is the rock slider/step to get in this bitch...
SNODOGG1 is offline   Reply With Quote
Old March 7th, 2008, 09:32 PM   #11
Pre4runner
Bike Dude
Pre4runner's Avatar
I was thinking the same... but put a little simpler if you push on a flat side it will take less force to bend it then on a corner of square tubing. So say a long section were to get some force applied to a flat side it will bend easier and maybe fail. Once square tube bends it keeps going and quickly.
Old March 7th, 2008, 11:16 PM   #12
Shotgun
Shotgun's Avatar
what if what u think is the flat side was actually a corner?so it would be sitting 45 degrees offset from how it would normally lay.
Old March 28th, 2008, 07:33 AM   #13
orionn
orionn's Avatar
First, the material plays a major role in the overall strength and durability of any type of tubing, even more than then thickness of it.
Remember that.
The biggest problem with Square tube is the way it handles stress loads.
The corners set up stress risers while the flats are under less load, especially torsionally. Ever seen pics of broken square tube? It general will have ragged tears and sharp, angular corners where the failure is. When square tube fails, its not prety.
It does handle an impact well, but the amount of force required to deform square tube is less on the flats, so in a roll, rocks, tress and things like that wil bend the cage faster than if it was round (due to the difference in how the flats and coners handle stress loads).
I have seen cages built and run, they will work, they do tend to be heavier than round tube, not to mention the corners are good head knockers when your getting bounce around, but its better than nothing.
BTW, square tube starts out its life as round tube.
orionn is offline   Reply With Quote
Page generated in 0.34040 seconds with 62 queries
