gears - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2008, 09:54 PM   #1
bones36
dont let your meat loaf
bones36's Avatar
Send a message via Yahoo to bones36
Default gears
im new to this so forgive me.....what is stock gears for front and back axles
on a 89 jeep cherokee
bones36 is offline   Reply With Quote
Old March 15th, 2008, 10:12 AM   #2
XJEEPBlack4.5
XJEEPBlack4.5's Avatar
There is a tag on the front of the axle cover that will have the information that you need, If the tag is gone, then take the cover off and look at the gears for a stamp#
or count the number of teeth on the ring gear. that should tell you.
all XJ's came with a couple of different gear ratio's. must common is 3:55's.
Hope this helps.
XJEEPBlack4.5 is offline   Reply With Quote
Old March 15th, 2008, 10:14 AM   #3
bones36
bones36's Avatar
hay thanks alot,im just starting to get into this stuff so all the help I can get is awsome
Old March 15th, 2008, 10:20 AM   #4
ddeadserious
ddeadserious's Avatar
Your transmission and motor decide what gear ratio you have. Let us know, and we can probably tell you.
Most 4.0L Manuals had 3.07s
Most 4.0L Autos had 3.55s and sometimes rarely 3.73s
Most 2.5L Manuals has 4.10s
Some 2.5L Autos had 4.56s
Hope that helps, I believe all that's right.
ddeadserious is offline   Reply With Quote
Old March 15th, 2008, 10:22 AM   #5
bones36
bones36's Avatar
well I have a 4.0 5 speed
Old March 15th, 2008, 10:26 AM   #6
bhunt
BigBri
bhunt's Avatar
quick easy way, you can jack up the rear and put it in nuetral and as you spin the rear tire count the revalutions of the drive shaft compared to the revs of the tire.
3:1 its probably 3.07
3 1/2:1 its probably 3.55 and so on.
bhunt is offline   Reply With Quote
Old March 15th, 2008, 10:28 AM   #7
bones36
bones36's Avatar
hay there ddeadserios,nice to see someone close bye,let me know if you ever want some help wrenching,I know alot about motors,but it's obviuse i know nothing about trans and gears lol
Old March 15th, 2008, 10:30 AM   #8
bones36
bones36's Avatar
thanks for all the help guy's,it wont be forgotton
Page generated in 0.22816 seconds with 47 queries
