D60:Semi Float, 5on5.5, disk brakes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 28th, 2006, 06:36 PM   #1
xj4life
xj4life's Avatar
Default D60:Semi Float, 5on5.5, disk brakes
I'm not sure yet what housing to start off with but I want to end up about 65" WMS. Haven't done much research into that yet as I can problaby get my buddy to narrow anything so i'm not real concerned. If anyone wants to chime in with a suggestion that'd be great. Then get custom 35 spline shafts with 5 on 5.5. I wanna use the Explorer disk brake setup that I already have, like Dynatrac and others do. Is this a bolt on brake setup? Any other problems I'd run into?
Old March 28th, 2006, 07:44 PM   #2
Hmm.. some ford Vans might be in that range..
Or a J-20..
Old May 12th, 2006, 10:51 AM   #3
PavementPounder
PavementPounder's Avatar
This axle already exists - Jeep used it in the late-60's, early-70's FSJ's. Its called the D60-2, is 5x5.5 with 35-spline shafts, and is really easy to convert to discs. PM Fullthrottle - he bought the one he built from me, did the disc conversion, and then sold the CJ-8 to 84Scrambler.
The 1 problem is that they are impossible to find and I'm an idiot for selling it.
Old May 12th, 2006, 11:15 AM   #4
xj4life
xj4life's Avatar
thanks, i'll have to keep my eyes pelled for one
Old May 12th, 2006, 11:48 AM   #5
PavementPounder
This is what you are looking for. Note the large 60-2 cast into the underside of the housing. Don't be surprised if you have to buy an entire Gladiator to get one. :tonka:
Old May 12th, 2006, 03:22 PM   #6
xj4life
xj4life's Avatar
well that makes it easy
Old May 22nd, 2006, 12:25 AM   #7
fullthrottle
2013 King of da Moustache
fullthrottle's Avatar
Send a message via AIM to fullthrottle
i might have a contact of a gentlemen selling one a few states from here :P
i still have his email if youd like it pm me. and ill dig it out
j4000 had the 60-2 5x5.5 more comonly then the other j trucks. :P
fullthrottle is offline   Reply With Quote
Old May 29th, 2006, 08:39 AM   #8
Strangler
Strangler's Avatar
I have one of the ebay sf 60's that were going around last year if you want it. The plug welds are only tacked in, so removing the tubes, shortening them to your desired length and reintalling would be simple. The ends are standard Dana which use the -2 bearings. Moser will sell you any length shaft for $280, and the bearings and retainer plate for $100. Come and get it, brand new. $75
Old May 29th, 2006, 12:53 PM   #9
fullthrottle
scott> that axle wouldnt have to be cut down i have 2 of them and after est wms that axles is perfect for a yj tj xj cj vechile as is just need shafts brake brackets calipers ...
best parts i found are waggy/chevy 6 bolt caliper bracket, same rotors, calipers and such but youll need a 6 bolt bearing/seal retaining ring on the shaft before the bearings are pressed in the bearings are from a d60-2 semi floater which u might get w/ the axles and if not can get through tricounty gear in cal!!!
also when u get the shafts ask to get a duel bolt pattern 6 lug or 5(big lug)
also see about the lug bolt being threaded in for easier swaps trail fixes!
Old May 29th, 2006, 01:16 PM   #10
Strangler
Strangler's Avatar
Well, if its perfect.... someone should buy it.
Old May 29th, 2006, 05:15 PM   #11
PavementPounder
Someone should list them in the For Sale Forum.
Page generated in 0.30177 seconds with 56 queries
