ranger questions - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 24th, 2008, 07:33 AM   #21
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
you would probibly have Vacum hubs on that ranger
Not on a 93, they have automatic mechanical hubs (weak). If you want to upgrade here go with the Warn manual lock kit.
Troll53 is offline   Reply With Quote
Old March 24th, 2008, 10:25 AM   #22
chris1044
chris1044's Avatar
Originally Posted by 04 EDGE View Post
your truck also has a totally different suspension
Um, no, he is asking about a 93 ranger. All rangers prior to 97 had the TTB/TIB front suspension (4wd/2wd, respectively). 98 + they went to SLA (short arm/long arm) IFS
My ranger could fit 31's no problem stock. It is a 94, which is IDENTICAL to a 93 is almost every aspect, including powertrain (save some have EGR's, some don't). No rubbing at all. Period. This was on stock rims, but as stated it is a 4x4 - on 2x4's you won't fit 31's.
Originally Posted by aimmotorsports View Post
which spacers? do they make them for a ranger or are they jeep ones? i dont remeber ever seeing them for a ranger. we were talking about it again today and all he wants is a 32"-33" tires. hes looking for more the look then anything. is the front axle vacum disco in the '93? i havent looked at it, but, it doesnt seam to be engaugeing the front axle.
I'm reffering to coil spring spacer, which go under the front coil springs and sit atop the beams. They typically raise the front end 2", but you'll need to align it after you do it...These are a good example
Now talking about the hubs, you DO NOT have vacum actuated front hubs. Those were never put on TTB front suspensions, they weren't produced until 98'. He more than likely has the factory "auto locking" hubs which use cam's to engage when they see the front axle shaft spin......they're week, and I'd recommend replacing them with Warns. If you're going to do it, get the stronger ones...Info found here
If you're going to be lifting it, keep in mind that the TOE change when the suspension cycles is what wears the tires, not the camber change.....look in the ford FAQ for a huge write up on the entire front suspension.....
Old March 26th, 2008, 10:32 PM   #23
EERNGER98
Taco driving jeep wheeler
EERNGER98's Avatar
Not on a 93, they have automatic mechanical hubs (weak). If you want to upgrade here go with the Warn manual lock kit. -
Now talking about the hubs, you DO NOT have vacum actuated front hubs. Those were never put on TTB front suspensions, they weren't produced until 98'. He more than likely has the factory "auto locking" hubs which use cam's to engage when they see the front axle shaft spin......they're week-
OOPS! DURRR... Total brain fart there, sorry guys. Anyhow the point i was trying to get to is exactly what everyone is saying....REPLACE DA HUBS!! A nice set of lockouts will stop the guessing about wheather your "in" or "out" of 4x4. It can be pretty frusterating taking the alternitive route of trying to make the crappy auto-hubs work, and even when they do work, they can mess up (but i guess that goes for anything). At least with ttb you can find Warn hubs and what not for them...the 98+ (before the live axle change) have a hard time finding replacements. Anyhow dont bother with the auto's take all our words for it, and just order a set of lockouts, you wont regret it!!
EERNGER98 is offline   Reply With Quote
Old March 27th, 2008, 09:40 AM   #24
barry1me
Just another day
barry1me's Avatar
Here was my buddies 03 FX4 with 3" BL and 33x12.5 MT's. Had to remove the mudflaps, and trim the front plastic about 1".
barry1me is offline   Reply With Quote
Old March 27th, 2008, 10:21 AM   #25
Oscoda02Ranger
Cops Don't Like Mud!
Oscoda02Ranger's Avatar
Send a message via AIM to Oscoda02Ranger
Heh, I have 31" BFG A/T's on my 02. And they rub on full tilt turns. I think its just the mudflaps though!
Oscoda02Ranger is offline   Reply With Quote
Page generated in 0.31967 seconds with 38 queries
