ranger questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2008, 03:52 PM   #1
aimmotorsports
aimmotorsports's Avatar
Default ranger questions
my brother in law want to lift his truck a little bit and was wondering what size tire would fit. hes lookin at doing a 2-3" body lift to start. possably suspension later.
aimmotorsports is offline   Reply With Quote
Old March 4th, 2008, 04:00 PM   #2
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
Depends on what year Ranger. The later generations can fit larger tires with no lift at all. A 3" lift on an 88 Ranger for example would accept 31's while 3 inches on a 97 Ranger would get you up to 32's or possibly 33's.
Troll53 is offline   Reply With Quote
Old March 4th, 2008, 04:11 PM   #3
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
yea my buddy has 31's on his ranger and a 3" BL and they are fine its a 2 gen ranger
Bronco Ollie is offline   Reply With Quote
Old March 4th, 2008, 04:42 PM   #4
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
on my '84 I have a 6" suspension lift on it, still had to trim to clear 33x12.50's. I've seen Gen 3 and up Rangers on 35's and I think one on 36's with about 7" of lift and full size fender flare cutouts, looked pretty slick.
Old March 4th, 2008, 05:41 PM   #5
aimmotorsports
yeah i forgot, its a '93
Old March 4th, 2008, 05:48 PM   #6
Bronco Ollie
my other buddy has a 94 with 30's and a 3" body lift and no rubbing at all
Old March 4th, 2008, 06:14 PM   #7
Daniel
SFA Ranger
Daniel's Avatar
i have a 97 2wd with 2" lift coils and 31's.
my lift coils will be forsale as soon as i start my SAS.
Daniel is offline   Reply With Quote
Old March 4th, 2008, 06:18 PM   #8
BlackBetty97
We Like it Loud
BlackBetty97's Avatar
I have a 97', gen 3 same as your brothers. Currently stock suspension with no body lift and im clearing 31's no issue. Im going to a 6 inch suspension and either a 3 inch Body lift or fiberglass front fender (providing i can find some cheap) and im gonna be running 35's.
BlackBetty97 is offline   Reply With Quote
Old March 4th, 2008, 07:35 PM   #9
chris1044
chris1044's Avatar
31's fit stock
32x11.50 & 33x10.50 will fit with 2" body...33x12.50 will fit on 8" rims with some trimming in the front.
3" body lift will fit 33x12.50's
FWIW, I have a 6" lift on my DD, run 33x12.50's, and have room for 35's with no body lift...
Also, if he wants to skip the whole body lift crap and get a quick 2", coil spacers in the front and an add-a-leaf in the rear is cheap and will allow 32's...maybe 33's...
Old March 4th, 2008, 07:43 PM   #10
Daniel
SFA Ranger
Daniel's Avatar
Originally Posted by chris1044 View Post
31's fit stock
32's are a tight fit, i would stick with 31's.
you could run 33's, but it would really be stuffed.
when i had the 31's on my truck without any lift it would rub on the wheel wells all the time.
Old March 4th, 2008, 08:44 PM   #11
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
im running a 94 and it had a 5.5in super lift and iwas running35s no problem and now im running about 7-9inchs of suspension lift and 37s but will be trimming fenders for more clearence.
Old March 5th, 2008, 09:52 AM   #12
chris1044
chris1044's Avatar
My truck stock had 31's on it....I never once heard the wheels rub - not a single time. Obviously, 4x4 rangers sit higher than 4x2's though.....
Old March 5th, 2008, 03:33 PM   #13
Daniel
SFA Ranger
Daniel's Avatar
this is true.
oh well, mine will be 4wd soon with a solid axle.
Old March 5th, 2008, 03:39 PM   #14
Bronco Ollie
yeah 4x4 sit higher then the 2wd ones
Old March 21st, 2008, 09:37 PM   #15
aimmotorsports
31's fit stock
which spacers? do they make them for a ranger or are they jeep ones? i dont remeber ever seeing them for a ranger. we were talking about it again today and all he wants is a 32"-33" tires. hes looking for more the look then anything. is the front axle vacum disco in the '93? i havent looked at it, but, it doesnt seam to be engaugeing the front axle.
Old March 21st, 2008, 10:40 PM   #16
Bronco Sally
Lets go wheelin
Send a message via MSN to Bronco Sally
my bronco ll(same thing as ranger) has 8" lift in front 7" in rear on 38s and only rubs when she flexed good... i had 31s on a stock 86 with minor rub...
Bronco Sally is offline   Reply With Quote
Old March 22nd, 2008, 12:11 AM   #17
EERNGER98
Taco driving jeep wheeler
EERNGER98's Avatar
I would go for a 3" if i were him/you. Its the go big or go home sort of thing...if you buy the 2" you will always wish you had the 3". Plus this will make it easy to work on things like removing the tranny when you want to replace the clutch (assuming its a stick) or just general upkeep. it makes things a little bit better under your rig. I ended up spending up my clutch (on the rig in my photo) and had to replace my clutch with no body lift. after we put on the body lift (4 months later i put on a 3" body lift) it would have been almost 2x faster after the body lift. (the ranger is stock size in the photo).
EERNGER98 is offline   Reply With Quote
Old March 22nd, 2008, 12:18 AM   #18
EERNGER98
EERNGER98's Avatar
If your talking abou the hubs, then no, you would probibly don't have Vacum hubs on that ranger. Auto hubs are always a pain in rangers. Tell your friend to go right for Lockouts if he narrows it down to the hubs...i probibly spent 2k trying to make mine work in actuators, noids, lines, and seals. i ended up finding a (Rare) lockout hub made for 98+ rangers and bought it right then and there, it was awesome knowing that the front end was enguaged. Lockouts for 93 - 97 rangers are a bunch easier to find.
Old March 22nd, 2008, 03:43 PM   #19
88mudder
In the band!
Id stick with 31s on a 2-3" lift
Old March 22nd, 2008, 05:04 PM   #20
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
your truck also has a totally different suspension
Page generated in 0.49219 seconds with 83 queries
