CB cable question for a TJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2008, 02:48 PM   #1
Bishop
Bishop's Avatar
Default CB cable question for a TJ
for those of you with CB's i am wondering how much cable to run.
will be mounting the antenna on the spare tire mount and the CB on the drivers side dash, i have heard not to coil up extra cable so just wondering if 9 feet would be good, my next choice would be 12' and dont want to have too much,
thanks
Bob
Old March 4th, 2008, 03:02 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
thanks
Bob
Best option would be to buy cable and install your own ends. Barring that, use string to find out how much cable you need and buy the closest match.
Old March 4th, 2008, 03:04 PM   #3
Lemur
i don't much care for you
Lemur's Avatar
i think i used 12 feet and i have a little 2 much slack... mounted the cb to the shift boot and the antenna in pretty much the same place... but i ran the cable around the passenger side underneath the inerior lift and then zip tied thur the existing holes in the rail.
3 questions unrelated....how tall is your antenna and what kind? and high high is your jeep lifted?
the reason i ask is i have a 4 or 5 foot (dont remember)firestik on a spring and i love it.. but i i'll be damned if i dont crack at least one a year on parking garages...pulling thru drive thrus and on trees... i try to keep it a foot above the roof....but it is usually higher than that
Lemur is offline   Reply With Quote
Old March 4th, 2008, 03:09 PM   #4
jeepnxj96
jeepnxj96's Avatar
i would go with 12 ft. you don't want to coil up a bunch of coax but you want to have enough for routing.
Old March 4th, 2008, 03:27 PM   #5
Ljltrucking
Ljltrucking's Avatar
Default cb
coax is to be used in 3ft increments, a spring on your antenna is fine until it gets rusty and loses ground and wont work properly, if you have a spring and start having problems replace the spring, mudrunner
Ljltrucking is offline   Reply With Quote
Old March 4th, 2008, 03:51 PM   #6
Bishop
Bishop's Avatar
it is a 3' firestik (firefly) on a stock rubicon
Old March 4th, 2008, 03:53 PM   #7
Lemur
Lemur's Avatar
thwen you will not have to worry about having the same problem as me....
Old March 4th, 2008, 03:54 PM   #8
Bishop
Bishop's Avatar
i went with the 9' cable and unnconected ends, if its too short i can ust get a new one, it was only 8 bucks
Old March 4th, 2008, 05:44 PM   #9
Eric 93 YJ
Northwest Ohio Crawlers
Eric 93 YJ's Avatar
I don't think the length of coax matters. I have a bunch of extra length. The antenna needs to be tuned to the length of cable. My CB gets out with the best of them. There are a couple differnt ways to tune your CB. Everytime you add a piece of steel near the antenna or move it you should tune the antenna.
93 YJ
http://www.northwestohiocrawlers.com
Eric 93 YJ is offline   Reply With Quote
Old March 5th, 2008, 01:53 AM   #10
Bishop
Bishop's Avatar
that was another question i had...
If i remove my antenna for whatever reason( carwash, low clearence or whatever) will it have to be re-tuned?
it isnt that big of a deal becauce of the antenna that i bought but just wondering if i should invest in my own SWR meter and get good at tuning, or just have it done once
Old March 5th, 2008, 05:28 AM   #11
Eric 93 YJ
Eric 93 YJ's Avatar
Check out his site for antenna tuning.
http://www.claysradioshop.com/SWR-setting.htm
Hope this helps.
93 YJ
Page generated in 0.53997 seconds with 56 queries
