question on 1 ton dodge rear end... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 3rd, 2008, 11:01 PM   #1
stevelknievel
Fuck Cancer
stevelknievel's Avatar
Send a message via AIM to stevelknievel
Default question on 1 ton dodge rear end...
my uncles got a 1 ton frame hes using for a car hauler and the drums are seized and he needs to remove them
i know this isnt super specific but does anyone know if the drums slide off? or does the hub have to come off with it?
stevelknievel is offline   Reply With Quote
Old March 4th, 2008, 05:49 AM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
If it is old enough that you just have a frame, most likely it is old enough that you will have to remove the hub as well to get the drum off.
Old March 4th, 2008, 07:13 AM   #3
yozsi
fully floating? if so, you have to remove the axles first....
yozsi is offline   Reply With Quote
Old March 4th, 2008, 12:09 PM   #4
stevelknievel
Fuck Cancer
thanks for the info guys ill let him know!
Old March 8th, 2008, 02:04 PM   #5
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
remove the axle shafts, then the 2 spindle nuts, then pound the studs out and the drum will fall off
ttocsnekia is offline   Reply With Quote
Old March 25th, 2008, 09:48 AM   #6
redleg
Use a big sledge and pound on the center of the shafts on the diamond shapde dimple, after you take the nuts off. It'll take some doing, but the shafts should pop, then work them out, easily.
redleg is offline   Reply With Quote
Page generated in 0.20163 seconds with 41 queries
