d ring mounts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 3rd, 2008, 01:55 PM   #1
jeepyj93
Sundowner
jeepyj93's Avatar
Default d ring mounts
I am building a new rear bumper. I have some Weld on d-ring mounts laying around, and i was wondering if it would be strong enough for a recovery point. The bumper is 2x4" and 3/8" thick. If I do this, I would have a professional weld it for me. Anyone use these mounts, or have any input. These are the d rings that i have sitting around. Would these work?
jeepyj93 is offline   Reply With Quote
Old March 3rd, 2008, 02:02 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
I use these:
http://www.jeeperz-creeperz.com/heav...ng-p-6754.html
No problems with using them as recovery points so long as the bumper is securely fastened to the frame.
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old March 3rd, 2008, 03:16 PM   #3
badazzamc
Get Some
badazzamc's Avatar
I have had two of those break on the car trailer, with just a vehicle starpped down. The trailer was only about a year old when it happen, so its not like rust was a factor.
Old March 19th, 2008, 07:17 PM   #4
cannaert
No more Jeep
cannaert's Avatar
I have two pn my rear bumper of my Jeep as recover points. Yanked on them a few times and no prob with them. Just make sure there is a good weld on them as long as the bumper is weld and bolted on as well
Old March 19th, 2008, 08:59 PM   #5
tjs0461
tjs0461's Avatar
x2 some are just a piece of round stock bent in a D ring if you weld the two ends together you should be ok .I would not use as a strap point but winch point should be ok
tjs0461 is offline   Reply With Quote
Old March 19th, 2008, 09:34 PM   #6
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
on my old front bumper I made clevis mounts out of two pieces of 3/8" angle welded into a "T" and put a 1" hole in the center. they mounted to the bumper centered on the frame horns with 4 grade 8 bolts each. never failed. I wouldn't use them on anything over a 32" tire. with the install of the 35's I made a rectangular tube bumper with 1" thick weld thru mounts.
Old March 19th, 2008, 09:43 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
ive got 10 on our trailer.. 6 that i added look like that.. and 4 other diff ones that came one.. i burned mine in with our old trusty licoln buzzbox arc welder.. havnt given up yet and theyve been put to use plenty.. as for tow points u use the tabs like J.C. Linked.. cept i made mine
Page generated in 0.26177 seconds with 44 queries
