Lifted bronco steering (more on pg. 3) - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2008, 08:55 AM   #41
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
I havent pulled it yet, doin that today after school, hopefully i will be able to finish it real quick so i can get the exhaust done and drive it.
as far as the exhaust, the cherry bombs sit right next to the t-case, one is farther back than the other, i dont know what it would entail to pipe it myself.
Bronco351 is offline   Reply With Quote
Old March 10th, 2008, 10:46 AM   #42
ddeadserious
ddeadserious's Avatar
Did you steal my gloves?
ddeadserious is offline   Reply With Quote
Old March 10th, 2008, 10:48 AM   #43
Bronco351
Powered by Ford
Bronco351's Avatar
there is a pair of yours in my garage, so yeah, i forgot to give them to ben to take back with the impact. Oops
Old March 10th, 2008, 10:48 AM   #44
88mudder
In the band!
tighten up the pitman arm tool on the arm. Hammer down on the bottom of the arm where it connects to the drag link. Tighten the tool up some more and hammer down on the arm. If you dont hammer down on the arm you will break the tool.
Old March 10th, 2008, 10:51 AM   #45
Bronco351
Powered by Ford
Bronco351's Avatar
Alright, sounds simple enough
Old March 12th, 2008, 08:49 AM   #46
Bronco351
Powered by Ford
Bronco351's Avatar
got the gearbox installed, not like i planned though, i ended up jacking up the front axle then aligning the pitman arm from there, but somewhere along the line, i messed up the drag link, so i need to get that fixed now.
EDIT: Specifically its the joint that connects pitman arm to the drag link, its got some play in it now.
Old March 13th, 2008, 09:55 AM   #47
03hemisilver
Pres MI Dodgetruckworld
03hemisilver's Avatar
That's normal any time your doing that, gotta "beat" those parts loose to get them out. Might as well replace some while your at it, tie rods, etc. Your probably gonna need an alignment anyway, do it right the first time
80 CJ frame, YJ body, 304 cid, 4" lift, 35"s, 4.10's, locked, 8K winch, garage queen
2012 F150 4x4 Lariat Supercrew Ecoboost
03hemisilver is offline   Reply With Quote
Old March 14th, 2008, 08:29 AM   #48
Bronco351
Powered by Ford
Bronco351's Avatar
thats my plan
also gonna need some 33x12.50 R15 tires soon too
Page generated in 0.21367 seconds with 47 queries
