Lifted bronco steering (more on pg. 3) - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 6th, 2008, 09:35 AM   #21
masterbeatty
masterbeatty's Avatar
thats what i did to myne cut the cat and i ran 2 40 series. sounds ok.
Old March 6th, 2008, 11:01 AM   #22
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
I think i am just going to run some tail pipe from the cherries and go straight back. should be sufficent enough, i would drive it as is but its too loud.
How difficult is it to replace the steering gear box??
Bronco351 is offline   Reply With Quote
Old March 7th, 2008, 08:21 AM   #23
masterbeatty
umm it took me a weekend only because i stripped the bolt heads off. but we did my dads excursion in under an hour start to finish.
Old March 7th, 2008, 09:59 AM   #24
Bronco351
Powered by Ford
Bronco351's Avatar
I am going to try to get it done tonight, if i can, along with the tailpipes, what did you do about the steering fluid?
Old March 7th, 2008, 11:21 AM   #25
ddeadserious
ddeadserious's Avatar
Let me know if you need a hand, I might be in the garage most of today as well. But if you break bolts, I've got a welder and some nuts we can weld on to get broken bolts out(which could very well happen)
As for the power steering fluid, what I've heard is that after you install the box, you just put fluid in the reservoir and fire her up and turn the wheel back and forth until it gets low, and add some more, and repeat until the fluid stays at the same level, meaning the steering box is full.
ddeadserious is offline   Reply With Quote
Old March 7th, 2008, 11:24 AM   #26
Bronco351
Powered by Ford
Bronco351's Avatar
im probably gonna need some help, my dad is working till 9:30 tonight and i want to have it done by sunday. i work until 7 so i cant do nothing until then. i may try to run some tailpipe tonight too.
Old March 7th, 2008, 11:29 AM   #27
ddeadserious
Well just let me know, I'm not totally sure of my plans yet, but you can use my electric impact, that should speed things up a little. Just give me a call if you get stuck and need a hand, just so you know, Ben's a pretty good helper.
Old March 7th, 2008, 11:32 AM   #28
Bronco351
Powered by Ford
Bronco351's Avatar
I will, Thanks
Old March 7th, 2008, 03:14 PM   #29
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
if ya need a hand i could probably help out. i am getting ready to do mine as well.
just let me know if ya need a hand.
Silver Bullet is offline   Reply With Quote
Old March 8th, 2008, 03:26 AM   #30
foxracingtrx250x
Broncosaurus
foxracingtrx250x's Avatar
Wait I just realized that bronco should have an 02 sensor before the cat well in this case on the muffler does it at all?
foxracingtrx250x is offline   Reply With Quote
Old March 8th, 2008, 10:28 AM   #31
Bronco351
Powered by Ford
Bronco351's Avatar
Not sure if it has one, i havent checked yet, i will today.
Got the gearbox off, it could very well be tthe most annoying thing i have ever done.
my problem now is getting the new gearbox.
if i was to get one from someone parting out a vehicle, what models would work?
Old March 8th, 2008, 11:42 AM   #32
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
on jeffs broncograveyard the power steering box they list(the only one they list) is for 80-96 broncos and f 150s, so pretty much any bronco or 150 thats even close to your year should work
broncobuddha is offline   Reply With Quote
Old March 8th, 2008, 11:49 AM   #33
Bronco351
Powered by Ford
Bronco351's Avatar
Just got a check in the mail, off to autozone to get the gearbox now, their price is cheaper than murrays. then i get to put the new one in, in the snow.
Next up, tailpipes.
Old March 8th, 2008, 03:18 PM   #34
Bronco351
Powered by Ford
Bronco351's Avatar
alright, this thing is being a pain to install, i have the splines all lined up but it still isnt going in, use grease maybe???
neeed help ASAP
Old March 9th, 2008, 01:44 PM   #35
Bronco351
Powered by Ford
Bronco351's Avatar
Alright, got that all taken care of, got another question though, how does one get the pitman arm off??? i have the castle nut off the bottombut it still wont come off.
Old March 9th, 2008, 01:56 PM   #36
Silver Bullet
i think you need a puller.
Old March 9th, 2008, 01:59 PM   #37
Bronco351
Powered by Ford
Bronco351's Avatar
That might work, My dad has all kinds of pitman arm tools and didnt tell me until after i needed them, he might have a puller of some sort for it.
Old March 9th, 2008, 02:06 PM   #38
Silver Bullet
haha thats how dads are let ya have a hard time, get pissed then tell ya oyeah by the way.
Old March 9th, 2008, 02:13 PM   #39
Bronco351
Powered by Ford
Bronco351's Avatar
he was gone the whole time i was working on it, i managed to get it most of it hooked up, but the pitman arm was giving me trouble. right now its 1/2 way on the box, with 1 bolt holding it to the frame, but the steering shaft ic connected. i am going to take off the pitman arm, put the other 2 bolts into the box, then put the top part of the pitman arm onto the box, then hook up the bottom of the arm. thats my plan and hopefully it will work.
Old March 10th, 2008, 08:54 AM   #40
masterbeatty
how did it go? pullin the pitman are does require a puller and some ever require a little hammering.
Page generated in 0.53199 seconds with 83 queries
