I just installed a 78 Ford D60 axle under my 82 jeep J10. It's setup with a SOA and 6 in spring lift. This gives me a 35 in long front driveshaft and 29 degree angle with a 2 degree up angle on Tcase. Put all that together and you have 2 binding ujoints when engaged. No problem because I was reading on Pirate that there is a joint that can go as far as 41 degrees. So I call to order the joint and it turns out that the ujoint at the diff is a size and type that they do not make. So here is what I think my options are:
1. Cut my perches, knuckle welds and rotate the diff and point it at the Tcase then reset the knuckles to the proper caster.
Don't really want to do this as I am not much of a welder.
2. Change the yoke on the diff and driveshaft to a size that the Chris Woods 41 degree ujoint is made.
Any other ideas? I open to whatever. I need to drive my rig to the trail but I don't need to operate in 4 wheel drive at freeway speeds. I also have a couple of other questions:
1. What is the maximum angle a double cardan can operate?
2. Can a double cardan be attached at either end of the drive line? (diff or Tcase)
82 J10 SOA 6" SPRINGS D60-D70 W/DETROIT LOCKERS 38x15.5 TSL'S on 12" M/T classics 460 V-8 C-6 Custom EFIS EFI AND HYDROBOOST
