sticky brakes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 29th, 2008, 07:02 PM   #1
Pdizzle
Pdizzle's Avatar
Default sticky brakes
ok my rear drum brakes stick in the morning -- is that just because it is so cold out that they are freezing up or is there something else wrong -- it has brand new drums and shoes and also wheel cylinders on it
Pdizzle is offline   Reply With Quote
Old February 29th, 2008, 07:59 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
ussally the drums stick or grab because they get wet or condinsate inside. also if the shoes wear to "fit" the drum. good shoes do not "fit". they rock when set in the drum. so if the shoes don't rock in the drum they are cut wrong. also you could have left greasy finger prints all over them. that in itself will ruin pads & shoes by making hot spots where they grab on the shoe and tear out chunks of material. clean with brake cleaner if you suspect this and don't be shy with it.
Yetti
Old February 29th, 2008, 10:15 PM   #3
Pdizzle
Pdizzle's Avatar
thanks i will try it
Page generated in 0.17225 seconds with 32 queries
