kerosene in a diesel? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 28th, 2008, 08:36 PM   #1
Grassman
2jz specialist
Grassman's Avatar
Default kerosene in a diesel?
a friend of mine told me i could run a tank of kerosene through my 7.3 diesel occasionally to keep her clean and running better. anybody done this? could you?
cc: maybe start a diesel tech forum?
Old February 28th, 2008, 08:38 PM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
We do this as part of our semi-annual maintenance on our diesel generator engines.
Old February 28th, 2008, 08:41 PM   #3
xj97sport
atv rider
xj97sport's Avatar
diesel tech forum would be a good idea
Old February 28th, 2008, 08:45 PM   #4
Bones
Bones's Avatar
i would be worried about the lack of lubricity eating the pump and injectors, plus any seals...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 28th, 2008, 10:33 PM   #5
xjmichigan
xjmichigan's Avatar
maybe kerosene with an additive?
Old February 28th, 2008, 11:09 PM   #6
fsumotorhead
N8KVB
fsumotorhead's Avatar
use bio instead, great lubricity and it's a solvent too
Old February 29th, 2008, 12:06 AM   #7
Grassman
2jz specialist
Grassman's Avatar
bio is more expensive than diesel, kerosene is cheaper right now, and bio will seperate in the cold if you let it sit i think
im just curious if it is a good idea to do once a month, quarter, or semi anually...
Old February 29th, 2008, 12:24 AM   #8
bigcountrysg
Countryboy
bigcountrysg's Avatar
You can do this. But as an additive to the diesel. I would not go over 1 gallon of kerosene for one full tank of fuel. So if your tank holds 30 gallons, you put in 29 gallons of diesel and 1 gallon of kerosene. I would not do this more then every 6 months.
But your best thing to do is to get a good fuel additive from companies like AMS, Lucas, or power service.
Another thing to do is to alternate one tank of regular ULSD and then one tank of Bio.
bigcountrysg is offline   Reply With Quote
Old February 29th, 2008, 01:16 AM   #9
cham
Inconsistant at Best.
I didn't think that bio separated in the cold, I thought that it turned into a sludge of sorts as it got colder.
cham is offline   Reply With Quote
Old February 29th, 2008, 01:19 AM   #10
Grassman
2jz specialist
Grassman's Avatar
i have heard if bio sits for an extended time it will seperate.
Old February 29th, 2008, 03:00 AM   #11
bigcountrysg
Countryboy
The stories you are hearing about bio seperating are from backyard bio makers. Commercially made bio will not seperate.
The sludge you are talking about happens to untreated diesel as well. It is called gelling. diesel will freeze but it takes extremely cold weather. How ever in the cold weather we have it thickens up and turns into a jello like substance.
Commercially made diesel that you buy at the pump is treated with winterizers from October-April. Usually during this time people that buy diesel complain about a loss in fuel mileage. The loss in fuel mileage is usually from the additives from the production of winter blend diesel.
Old February 29th, 2008, 07:19 AM   #12
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Run a tank of B20 through, but wait until Spring. Crystal Flash doesn't even sell B20 in the winter due to potential gelling issues. However, it should things out well (you'll just need to change filters after running it through).
Craig
Old February 29th, 2008, 07:47 AM   #13
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Dont get caught with a full tank of kerosene, no rd tax, big fine
Old February 29th, 2008, 07:59 AM   #14
Bubbathegreat_9
Probably Stuck
Bubbathegreat_9's Avatar
Send a message via Skype™ to Bubbathegreat_9
I run b20 in my diesel and it's never been an issue. Even on cold days. Infact I ran Bio on my last trip to Escanaba (during the last major storm we had, it was an emergency trip). The bigger problem with Bio is finding it. As far as I am aware it's only in Wixom and Centerline in the metro Detroit area. Sure it's a little more, like a nickel. Big deal. Between that and the synthetic oil I've had 127,000 trouble free miles.
Bubbathegreat_9 is offline   Reply With Quote
Old February 29th, 2008, 08:43 AM   #15
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I use the place in Wixom when I'm passing through. They only offer B5. I haven't noticed a price difference between them and other places. It's definitely cheaper than the station near my house at Clyde & US-23; that place is always at least $0.10 more a gallon.
I've only seen B20 once, and that was a truck stop near the Cliffs in Illinois.
Old February 29th, 2008, 08:54 AM   #16
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
we run jet a (or avaiation kerosene) in out diesel trucks at the airport......it burns better and cleaner and a tank last about a day longer than when we put diesel in em
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old February 29th, 2008, 08:55 AM   #17
M5B6L
Typical White Person.....
M5B6L's Avatar
Send a message via AIM to M5B6L
Ypsilanti Meijer has biodiesel as well, just not sure about their ratio of it.
M5B6L is offline   Reply With Quote
Old February 29th, 2008, 10:24 AM   #18
busyfixin
Balls Deep
busyfixin's Avatar
here is a list of bio stations in michigan.
http://www.biodiesel.org/buyingbiodi...tate.asp?st=MI
Old February 29th, 2008, 10:53 AM   #19
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
that list would be even cooler if I could put in my zip and it would sort in proximity to my house.
Old February 29th, 2008, 10:56 AM   #20
busyfixin
Balls Deep
busyfixin's Avatar
i think there is one, but i dont remember the addy.
Page generated in 0.54118 seconds with 83 queries
