Steering Linkage - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 28th, 2008, 07:23 PM   #1
Sandals
Fucking Zen as Shit
Sandals's Avatar
Default Steering Linkage
Ok, so going high steer with 1 ton TRE's, what would you recommend for links?
Dom? Mild Steel? Find something junkyard that will fit?
Old February 28th, 2008, 07:59 PM   #2
95geo
newbie
95geo's Avatar
for the 7/8-18 shank TRE's I like to use 1.25x.25 DOM drilled slightly over the existing .750" I.D. and then tap the tube itself.
Old February 28th, 2008, 08:37 PM   #3
Thats what I use on mine - 4130 tube...
If you've truly got it as high-steer, you probably won't be hitting it on to much, though, see attached pic for reference. You can see the tie rod sticking out the sides above the knuckles. That tie rod has never hit a rock, as far as I have seen, no rock-rash on it. During that same 2 years, I've destroyed one set of spring hangers, dented the last axle housing, in general bashed the the old and new front end.
Old February 28th, 2008, 09:13 PM   #4
Sandals
Fucking Zen as Shit
Sandals's Avatar
Yes will be true high-steer ( at least thats what i think i bought from adam lol)
I might need to come to kzoo to tap the DOM
Page generated in 0.19948 seconds with 35 queries
