Shackle Mount ?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 28th, 2008, 01:43 PM   #1
fsumotorhead
N8KVB
fsumotorhead's Avatar
Default Shackle Mount ??
Ok what is pictures below is my idea for my front hitch. I marked up a drawing of the front receiver I have on order for my X. I want to make either two tow loops like in #1 and welded to the bottom side for the winch hook and easier strap pulls, or two shackles mounts like in # 2&3. I figured Id use or 1 plate cut in the design in the second pic so it could be welded on top and bottom and in the front. Pic #3 shows my idea for lateral stability for angled pulls.
So which idea looks best?
I figure idea 3 with brackets below.
On a second note, anyone able to cut these brackets out for me, and if so how much?
I know i suck at drawing, but i think you get the idea. Not Drawn to scale either
Old February 28th, 2008, 01:48 PM   #2
bearlys2005
bearlys2005's Avatar
Look up TAB on this site, he has a CNC and should be able to cut these.
bearlys2005 is offline   Reply With Quote
Old February 28th, 2008, 01:52 PM   #3
jeepnxj96
jeepnxj96's Avatar
i've got access to a whole cnc shop if you wanna come out one saturday.
Old February 28th, 2008, 02:02 PM   #4
fsumotorhead
N8KVB
Allegan is a bit of a haul, but i'll keep it in mind
Old February 28th, 2008, 02:14 PM   #5
Monster4.0
Monster4.0's Avatar
why not use a reciever shackle instead?
Old February 28th, 2008, 02:15 PM   #6
fsumotorhead
N8KVB
Cause i will be using a receiver winch mount, therwise it would be a no brainer
Old February 28th, 2008, 02:16 PM   #7
fsumotorhead
N8KVB
That makes me think though
should i attach the shackle mounts to the receiver frame, or to the winch cradle even?
I'm thinking the receiver frame is much stronger
Old February 28th, 2008, 02:24 PM   #8
CreativeFab
used to be Ironman
CreativeFab's Avatar
You are not going to want these cut with Tabs machine, a plasma CNC table. At least not his, you will want these shackle mounts to be at least 3/4" thick as to not bend them if you were not doing a straight on pull. Most plasma cutters are only going to sever 1/2" and screw up 3/4". Unless you know someone with a bigger machine.
Buy 3/4" or 1" flat bar and use a band saw for the "fish mouth"
Page generated in 0.29955 seconds with 47 queries
