AOD Mercon V? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2008, 10:45 PM   #1
88mudder
In the band!
Default AOD Mercon V?
AOD's call for Mercon V trans fluid. I went to Murrays and found regular ATF and it says it covers Mercon fluids. Does anyone know if this means what it sounds like? I just dont wanna dump it in there and see my trans blow. Btw the trans is out of a '90 fullsize bronco.
Old February 27th, 2008, 10:50 PM   #2
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
well i would think if it says it covers it then it should be fine
Bronco Ollie is offline   Reply With Quote
Old February 28th, 2008, 10:18 AM   #3
88mudder
In the band!
anybody else?
Old February 28th, 2008, 11:22 AM   #4
mooseracing
Stuck like a MoFo
mooseracing's Avatar
Send a message via AIM to mooseracing
If it specfically states it meets Mercron V standards, then its fine. Most mercron V is part to full syn is why its around 3bucks a qt.
mooseracing is offline   Reply With Quote
Old February 28th, 2008, 11:53 AM   #5
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
like he said if it says it meets or exceeds the M-V specifications its good to go
broncobuddha is offline   Reply With Quote
Old February 28th, 2008, 05:38 PM   #6
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
it meets "mercon" specs, NOT mercon V specs
mercon and dextron 3 are all old standard atf and should not be used for a trans that calls for mercon V
99 cent fluid is not $4.59 a quart fluid. thats what i payed for valvoline a wile back
Old February 28th, 2008, 08:15 PM   #7
s.hembree
s.hembree's Avatar
Unless your trans is not original it should not require Merc V. That fluid was not introduced until the late 90's. Your AOD should use standard DextronIII/Mercon
Old February 28th, 2008, 09:53 PM   #8
88mudder
In the band!
are you positive?
Old March 15th, 2008, 09:25 AM   #9
My91Ranger
Ford Ranger
My91Ranger's Avatar
I have a rebuilt AOD in my truck. The trans guy I have rebuild all of my trans says Dexrom III / Mercon is the best fluid for the AOD.
My91Ranger is offline   Reply With Quote
Old March 15th, 2008, 12:25 PM   #10
88mudder
In the band!
thats what i used + added the additive just to be safe.
Page generated in 0.24777 seconds with 53 queries
