Radiator leak TJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 12th, 2005, 05:32 PM   #1
Pongking23
CHOP'S Idol
Pongking23's Avatar
Send a message via AIM to Pongking23
Default Radiator leak TJ
Went to disconnect the battery today, and looked and saw my radiator is leaking. Fluid was comming out the corners of the top cap of the radiator and would extend on the sides and for about 2 inches in the front. I was about 1-2 cups of fluid low......any help here?.....do i need a new radiator and if i do does anyone have one?
Pongking23 is offline   Reply With Quote
Old November 12th, 2005, 09:00 PM   #2
Chop
Mischievous Badger
Chop's Avatar
nope its good
Old November 12th, 2005, 09:17 PM   #3
Sonicjay
Is it coming out from under the cap, or further down on the neck? If it's under the cap, get a new cap first ($5), then a new radiator if not (more $).
Sonicjay is offline   Reply With Quote
Old November 13th, 2005, 12:18 AM   #4
Pongking23
CHOP'S Idol
Pongking23's Avatar
no, its out of the radiator cover....the big plastic things that covers the entire radiator, not just the cap
Old November 13th, 2005, 07:10 AM   #5
5.9zj
5.9zj's Avatar
double check the cap if that is not it, it is more than likely leaking where the plastic radiator "tank" is crimped to the aluminum core.
5.9zj is offline   Reply With Quote
Old November 13th, 2005, 09:58 AM   #6
Pongking23
CHOP'S Idol
Pongking23's Avatar
yes, it is leaking where the top of the radiator is crimped in to the radiator.......
Old November 13th, 2005, 11:43 AM   #7
5.9zj
5.9zj's Avatar
Time for a new one. make sure your new one is all metal. I think I got mine last year from radiator.com. price was pretty good for one that three row all metal replacement.
Old November 13th, 2005, 07:24 PM   #8
Big Daddy Rubicon
There watching me! (.)(.)
Big Daddy Rubicon's Avatar
Yes you will need to replace it. No way to fix a plastic/ aluminum radiator good.
[QUOTE=a.j. hall;1528363]
[/QUOTE]
Old November 18th, 2005, 08:25 AM   #9
groo
groo's Avatar
I had 2 radiator do that under the 3/36
so you might not want to go oem replacement
groo is offline   Reply With Quote
Old November 18th, 2005, 11:26 AM   #10
4-PLAY
4-PLAY's Avatar
Replace it. and upgrade to a 2 or 3 core
4-PLAY is offline   Reply With Quote
Old November 19th, 2005, 12:18 AM   #11
Pongking23
CHOP'S Idol
Pongking23's Avatar
i replaced it to a full steel 3 core rebuildable core radiator........should do the job
Old November 19th, 2005, 11:44 AM   #12
Blackjackbender
happened to me too.
was going to go with a 3 row from radiatorbarn.com or radiator.com forgot which one it was. went to Murrays to get a replacment one which was 2-row and all metal, has a lifetime warrenty on it so if i have another leak i can just go pick one up at a local murrays. cost about 160 i think.
Page generated in 0.30237 seconds with 59 queries
