swapping a 4.0L i6 Head - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 26th, 2008, 03:16 PM   #1
namesmud
namesmud's Avatar
Default swapping a 4.0L i6 Head
Hey -
Ive got this 91 XJ Cherokee that had overheated and cracked the head -
I was going to get another head and bolt it on replace the head gasket and call it good ...
Now my question is ..
Will this work ? Or does everything need to be matched somehow to the engine?
Do i have to take the new head to a machine shop and have them make sure its good ?? Or will they need both the head and the engine to do this ?
Does the head have to be all revalved and everything ?
Kind of a backyard mechanic so I dont really know all this stuff..
I tried to just replace the bad head gasket and bolt it all back together but it didnt work... the engine runs really ruff.. the crack was between cylinders... not actually on a cylinder so i thought it would still be ok ...???
Also didnt put all the really hard to get to bolts back in the intake manifold...
will this affect it alot ?
namesmud is offline   Reply With Quote
Old February 26th, 2008, 03:47 PM   #2
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
not putting all the bolts in will make a big difference, that's why there are so many and a torque sequence your supposed to follow! I'm guessing that you prolly f'd up your new head gasket by not putting all the bolts in. Just bolting on a different head would do no more damage or be no more risky then what you already did IMO
71jeepster is offline   Reply With Quote
Old February 26th, 2008, 03:56 PM   #3
Pokerob
hug life
Pokerob's Avatar
Old February 26th, 2008, 04:24 PM   #4
2JEEPS
Master Tech
2JEEPS's Avatar
Default Cyl head tech
I recommend that any used head should be ckecked over by a machine shop. The intake and exhaust manifold bolts are very important that they are tightend properly (they suck to do) The block only needs to be cleaned well along with any other gasket surfaces. You may have a vacuum leak at the intake causing the rough running.
2JEEPS is offline   Reply With Quote
Old February 27th, 2008, 12:56 PM   #5
namesmud
namesmud's Avatar
K .. Just to make it clear ...
The BOLTS ON THE HEAD ARE ALL INSTALLED/TORQUED to Speck !!!!
Its the bolts that hold on the exhaust / Intake that I chinched out on cause there impossible to get to !!
Old February 27th, 2008, 12:57 PM   #6
namesmud
namesmud's Avatar
If anyone has a Head thats not F-ed ... Let me know ! By F-ed ... I mean Cracked/warped !
Thanks
Old February 27th, 2008, 04:35 PM   #7
71jeepster
71jeepster's Avatar
Ok but without having the intake torqued to spec could still cause it to suck air and be causing the problems!
Old February 27th, 2008, 04:38 PM   #8
xjmichigan
xjmichigan's Avatar
If you got the bolts out, you surly can get the bolts in.
Old February 27th, 2008, 05:09 PM   #9
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Take it to a shop since it beyond your capabilities to do the job corectly.
Old February 28th, 2008, 01:40 PM   #10
namesmud
namesmud's Avatar
i will punch you ! job correctly .... I got a Job for You !
Old February 28th, 2008, 06:13 PM   #11
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
I have installed 6 exhaust manifolds on 4.0L jeeps in my day and I have never had a problem getting to the bolts on the manifolds.
Old February 28th, 2008, 07:51 PM   #12
PavementPounder
PavementPounder's Avatar
What Rocky meant to say was take it to a shop because you are obviously unwilling to do the job correctly.
You asked for help. People told you what you did wrong. If you're not willing to do it right, we're willing to let you fail.
Old February 29th, 2008, 08:20 AM   #13
Enginecraft
Custom engine machining
Enginecraft's Avatar
What's the 4 digit casting # on the head by the valve cover rail. I might have one.
Enginecraft is offline   Reply With Quote
Old March 2nd, 2008, 05:56 PM   #14
namesmud
namesmud's Avatar
Its says 7120 on it then further down it says L07 -
Whats the deal with the casting numbers ? Do i have to find another head with the same casting number ?
What if the numbers dont match ?
Also i have never dont this before so do i need to do anything to a doner head before i bolt it on ?
How do heads crack ? Trying to figure out how this happened !
My feeling is it over heated and cracked..
Old March 2nd, 2008, 09:57 PM   #15
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
Year............Casting No
1987-90......2686
1991-95......7120
1996-98......0630
1999-04......0331
Any 7120 should work. a 0630 would work but you won't have a place for the temp sensor.
http://www.greatlakes4x4.com/showthread.php?t=661
Old March 3rd, 2008, 09:20 AM   #16
namesmud
namesmud's Avatar
Ok - Soo I need one from a 91-95 .. .good thing i found that out ..
I was about to buy a head from a 98 ! Didnt even know ... thought they were all the same !
How about head gaskets ... Do i need a all metal gasket or is the murrays gasket fine ?
Thanks !
Old March 3rd, 2008, 11:42 PM   #17
xjmichigan
xjmichigan's Avatar
Remember,
Head bolts are torque to yield and should not be reused. For all the work you have done change them.
Old March 4th, 2008, 02:07 AM   #18
scorpiansniper
engine / paint tech
scorpiansniper's Avatar
Send a message via AIM to scorpiansniper
keep a couple things in mind too to different of a head gasket can change compression ratio to try to stick with oem unless you have in head or block machined also if you don't put all the bolts back in the intake manifold it'll prob run like shit cause diamler Chrysler has always used map sensors and still are to calculate air fuel ratio so having bolts loose or missing in the air intake will throw this off.
scorpiansniper is offline   Reply With Quote
Old March 4th, 2008, 04:40 AM   #19
jeepnxj96
jeepnxj96's Avatar
sounds like you should just have someone do the work for you. just reading this post and your comments i wouldn't let you touch any vehicle that needed work.at the very least have someone there who knows what they are doing. a job isn't worth doing if you don't do it the correct way.
Page generated in 0.37957 seconds with 80 queries
