Bad Gas? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 25th, 2008, 06:00 PM   #1
Sandals
Fucking Zen as Shit
Sandals's Avatar
Default Bad Gas?
So I put 5 gallons of fresh gas in 9 months ago...... the rest of the gas in there is at least a year older.
Trying to get it running today and it'll start to catch and then stop, getting gas, getting spark, wont stay running.
I really dont want to pump out the ~10 or so gallons and then find something to do with it once its out of there, but i'm leaning towards that being the culprit
Old February 25th, 2008, 06:07 PM   #2
Certainly possible. If you are of the type that use it, you can try starting fluid. Often once it goes, it'll stay running just fine.
If it's cold, and you had summer gas, can *sometimes* be finicky about it. The summer gas has a lower reid vaopr pressure and condenses on cold manifolds. I had one motor that refused to run winter gas in the summer....
Carb or FI?
Carb, its easy enough to rig a temp tank from a bottle or something with fresh stuff.
Old February 25th, 2008, 06:08 PM   #3
Smiley23
Smiley23's Avatar
Pull one of your plugs. Burning bad gas will foul your plugs. So you will know for sure if it is the culprit.
Smiley23 is offline   Reply With Quote
Old February 25th, 2008, 07:48 PM   #4
jeepguy74
jeepguy74's Avatar
what i would say is that the carb is varnshed up and needs to be cleaned ....we do the carbs on our motorcycles and snowmobiles before each season and i do this because i had a snowmobile motor go poof because it was running too lean because of dirty jets.....so i would guess that it is gummed up
Old February 25th, 2008, 08:30 PM   #5
Sandals
Fucking Zen as Shit
Sandals's Avatar
well one of my issues is it's the TBI i'm putting on and not 100% tuned, but last time i was able to get it idling. i'll try starting fluid in the AM and if it takes off with the i'll drain the tank at least it has an electric pump so i can just pull the line off the pump and run it into a can
Old February 28th, 2008, 04:19 AM   #6
scorpiansniper
engine / paint tech
scorpiansniper's Avatar
Send a message via AIM to scorpiansniper
cars are picky about there gas it does go bad they do make preservatives for it. they even change the gas at the pumps for winter and summer to help the cars run better for there conditions. so the gas could've gone bad, got water in it ect.
scorpiansniper is offline   Reply With Quote
Old February 28th, 2008, 05:42 AM   #7
bearlys2005
bearlys2005's Avatar
I'd try an additive for the fuel before I get rid of it. Also some injector cleaner may help to get it run through. With enough you additive you should be able to run it through.
bearlys2005 is offline   Reply With Quote
Page generated in 0.59256 seconds with 44 queries
