Questions on 1986 Ford Ranger??? Please help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 24th, 2008, 04:24 PM   #1
JeepGirl88
JeepGirl88's Avatar
Default Questions on 1986 Ford Ranger??? Please help
well i go to crank the truck over and it doesnt do anything... the battery is charged and i got lights in the truck, but the motor wont crank over or the starter wont engage... triied to jump the selinoid and didnt do anything any ideas.....
JeepGirl88 is offline   Reply With Quote
Old February 24th, 2008, 04:40 PM   #2
Hoofinit
Hoofinit's Avatar
Make sure the grounds are tight I had a loose connection on my block once everything engaged but the starter.
Tim
Hoofinit is offline   Reply With Quote
Old February 24th, 2008, 04:42 PM   #3
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
check the connections to the starter and its ground, if that looks good take your starter off and take it to autozone or some other place that tests them for free, if you have power and jumping the solenoid doesnt do anything its probly the starter
broncobuddha is offline   Reply With Quote
Old February 24th, 2008, 07:34 PM   #4
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
definitely sounds like a connection issue
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old February 24th, 2008, 08:34 PM   #5
muddywater
Stacks bring the awesome
muddywater's Avatar
Send a message via AIM to muddywater Send a message via Yahoo to muddywater
i had the same problem in my 90 and it was teh ground to teh starter so i just put a 10 gauge wire from teh bell of the starter to teh frame and its great now. but for sure have the starter checked first
muddywater is offline   Reply With Quote
Old February 24th, 2008, 09:29 PM   #6
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
yeah man sure the ground is good and the starter is still good to
Bronco Ollie is offline   Reply With Quote
Old February 24th, 2008, 11:28 PM   #7
JeepGirl88
JeepGirl88's Avatar
ill check the ground wire tomarrow... but i dont know... the starter is fine... i know that...
Old February 25th, 2008, 04:17 PM   #8
smasheromalley
smasheromalley's Avatar
How do you know the starter is fine? If you jumped the solenoid the only thing left is the starter and the wire leading to it ???
The starter could be only a week old, but that doesnt necessarily mean its good
Old February 25th, 2008, 08:51 PM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
doesn't anyone know that the starter is grounded to the engine block, cuz there kinda bolted together? you guys must mean the cable going from the battery to the engine block...:tonka: as everyone stated make sure the connections to the starter are good, if that don't work pull the starter and you can test it yourself with some jumper cables and see if it's good or just take it to autozone and let them do it.
Old February 26th, 2008, 04:54 PM   #10
JeepGirl88
JeepGirl88's Avatar
ya thanks im gonna test it later... pretty sure the starter is good but i dont know.. i have no clue what else it would be though
Old February 26th, 2008, 05:00 PM   #11
jeepnxj96
jeepnxj96's Avatar
if it is an auto tranny could be the neutral safety. that would explain all power but no starter engagement
Old February 26th, 2008, 05:00 PM   #12
jeepnxj96
jeepnxj96's Avatar
move the shifter from park and then back into park or try starting it in nuetral. only works if it is an auto trans though.
Old February 26th, 2008, 05:14 PM   #13
dumperdave
dumperdave's Avatar
It would still start when jumping solenoid if it was the nss.
dumperdave is offline   Reply With Quote
Old February 26th, 2008, 05:30 PM   #14
jeepnxj96
jeepnxj96's Avatar
hey it was just a guess,and something easy to try. stranger things have happened
Old March 10th, 2008, 01:44 AM   #15
Bronco Ollie
so did you ever get it running?
Old March 10th, 2008, 04:09 PM   #16
Bronco Sally
Lets go wheelin
Send a message via MSN to Bronco Sally
well if its not a ground, hit that starter with a hammer while some one tries to crank it over..
Bronco Sally is offline   Reply With Quote
Page generated in 0.28418 seconds with 71 queries
