what vehicle did this come from. **Now with pics** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 23rd, 2008, 07:13 PM   #1
Shotgun
I only wheel with boats.
Shotgun's Avatar
Default what vehicle did this come from. **Now with pics**
d-44 axle
code c-30294
from the tag 941595
From the tag it says 4.27 gears
thanks
Old February 23rd, 2008, 07:35 PM   #2
sodapop
Support the Sport!
sodapop's Avatar
neither of those numbers work in the Dana BOM (bill of material) site, maybe look for a different number in spot #2:
Dana BOM link
http://www2.dana.com/expert/wc.dll?cvsp~deabill~2~
Old February 23rd, 2008, 07:50 PM   #3
Is it a front or a rear?
What is the bolt pattern?
Axle width?
Spring type and perch/pad spacing?
Its 2008, can't you just post a picture?
I'll make a blind guess...
Dana 44 with 4.27s, hmm, narrow track early 70s 6 cyl Jeep rear axle?
Old February 23rd, 2008, 07:54 PM   #4
Shotgun
Shotgun's Avatar
Axle width?
its a jeep 5x5.5
rear axle
umm yeah its dark out side for the pic but BRB with 1 fer U
Old February 23rd, 2008, 08:02 PM   #5
Well, Dana 44 rears with 4.27s in Jeeps were factory axles in the 60s and 70s.
If its narrow, around 51" wide, then its from a CJ5 or 6 (or a 3b). Offset = pre 72, centered is 72-75.
Old February 23rd, 2008, 08:06 PM   #6
Shotgun
Shotgun's Avatar
It's almost as wide as a late 70's ford dana 60.
1968818 and 2018188 are the other codes on the axle. Could not find any on the tubes.
Old February 23rd, 2008, 08:59 PM   #7
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I am gonna guess J-Truck
Old February 23rd, 2008, 09:33 PM   #8
busyfixin
Balls Deep
busyfixin's Avatar
me too. early j-truck. could be from an FC as well.
Old February 23rd, 2008, 09:39 PM   #9
I'll guess some kind of International travel all.. J-trucks were 6 on 5.5 (not sure about the ealy ones..).
The scouts were also available in 4.27 gears, travel-alls were wider than scouts. Had a wide frame, whatever it was.
Old February 23rd, 2008, 09:57 PM   #10
busyfixin
Balls Deep
busyfixin's Avatar
early j-trucks were 5 lug. could be IH they used alot of 4.27's.
Old February 23rd, 2008, 10:50 PM   #11
Shotgun
Shotgun's Avatar
is it worth anything?
Old February 24th, 2008, 01:55 PM   #12
Whatever it is, its probably 30+ years old. Its just a dana 44, and very few people would be running 4.27s in the front, so regearing is probably necessary for someone to use it.
At that width, most people want a 60 or stronger. IMO, worth about $50-$75 unless you have someone who needs that exact axle..
Old February 24th, 2008, 09:41 PM   #13
Shotgun
Shotgun's Avatar
so most likely scrap it is?
Old February 25th, 2008, 11:42 AM   #14
PavementPounder
PavementPounder's Avatar
Most likely post it on IFSJA.org cheap and someone will come for it.
Page generated in 0.28441 seconds with 65 queries
