Toyota Traction Bar - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 23rd, 2008, 08:16 AM   #1
sr522re
Zip tied Tough
sr522re's Avatar
Default Toyota Traction Bar
I'm looking for a cheap and easy way to prevent axle wrap on my 85 Toyota. I've got a lot of bouncing going on and I don't like it. My truck is an extended cab and I believe it was a long box (don't have the box anymore). If you could offer any suggestions I sure would appreciate it.
Thanks,
Chris
sr522re is offline   Reply With Quote
Old February 28th, 2008, 12:26 PM   #2
Rattler
Home Sweet Homicide
Rattler's Avatar
Pro Comp makes traction bars for Toys. Performance Products has them in their catalog.
Old February 29th, 2008, 08:15 PM   #3
aimmotorsports
aimmotorsports's Avatar
if you can weld you can make them cheap with parts from tractor supply. like $30-$40
aimmotorsports is offline   Reply With Quote
Old March 8th, 2008, 09:59 PM   #4
scubarunner
UPPER('4x4') = '$X$'
scubarunner's Avatar
Have you looked at an add-a-leaf? They stiffen the springs up quite a bit and even add a bit of lift. They worked well on my 4Runner when it was in stock form. Picked them up from Summit for cheap.
scubarunner is offline   Reply With Quote
Old March 9th, 2008, 12:02 AM   #5
Pre4runner
Bike Dude
Pre4runner's Avatar
if you can weld or know someone who can its pretty simple to make one. 2 points of attachment at the axle spaced a few inches apart, 6 or so. then a simple shackle attached to a cross member and you are all set
Page generated in 0.21295 seconds with 38 queries
