torching near my gas tank? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 22nd, 2008, 06:07 PM   #1
robrocketanski
Default torching near my gas tank?
Does anyone see a problem with cutting off this rusted shackle hanger? My gas tank is on the other side of the frame.
Obviously it sounds dangerous but I just need to torch off the heads of the rivets. The heat should never be enough to get to the tank right??
I am pretty sure it's fine, I just thought I would see if anyone is sure it would blow up....
And nice rust on that American frame!
robrocketanski is offline   Reply With Quote
Old February 22nd, 2008, 06:37 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
So long as you don't have any leaks, it should be fine if you're careful (so long as you don't shower it in sparks and heat). If the tank is full there's less chance of it exploding :tonka:
You can also take a die grinder and cut an "X" in the rivet head then use an air chisel to knock the head off.
Old February 23rd, 2008, 08:15 AM   #3
robrocketanski
Thanks!
I am trying to be nice to my neighbors and not make all the noise of a grinder, which will backfire if it blows :p
I think it will be ok.
Old February 23rd, 2008, 09:50 AM   #4
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
put a sheet of sheet metal or some sort of scrap in there to block sparks even ply wood works as long and you dont shower it with sparks all the time
Old February 23rd, 2008, 10:10 AM   #5
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
and be absolutley sure that any plastic gas lines and connectors are covered if your jeep has those
broncobuddha is offline   Reply With Quote
Old February 23rd, 2008, 11:38 AM   #6
I've done similar, without issue sevreal times. What I do is get a large towel and get it wet and throw it over the tank and lines.
Old February 23rd, 2008, 12:29 PM   #7
busyfixin
Balls Deep
busyfixin's Avatar
like the above said. put a pice of tin, wood, or street sign in between the tank and frame rail, and cover the lines and sending unit with some wet cloth.
Old February 23rd, 2008, 01:33 PM   #8
PavementPounder
PavementPounder's Avatar
Do any of the above suggestions. I like the wet towel. Use gravity and cut in a downward direction.
Old February 23rd, 2008, 10:56 PM   #9
scottie
Eye candy
scottie's Avatar
they also make special blankets that you could use that torches can't burn very easily
Old February 23rd, 2008, 11:01 PM   #10
fsumotorhead
N8KVB
fsumotorhead's Avatar
I would use an air chisel myself
Old February 23rd, 2008, 11:11 PM   #11
bigcountrysg
Countryboy
bigcountrysg's Avatar
Wimp, be a man torch it.
I done this a few times and I never had any blow up or catch on fire.
bigcountrysg is offline   Reply With Quote
Old February 24th, 2008, 06:35 PM   #12
robrocketanski
It was fine. I thought it would be. There is no room to do anything behind it. The tank is tight to the frame. It's the rear tank on an F-250 and I found out after I was done that there is a wire loom behind the top rivets:tonka:
Everything is good except that I couldn't get the bolt out of the spring bushing. So later I will replace the bushing I guess. No big deal but I didn't have a new bushing when I was doing it.
Thanks all!
Old February 24th, 2008, 07:32 PM   #13
kkodet
kkodet's Avatar
Just torch the tank straps first, and remove the tank
Old March 4th, 2008, 10:43 PM   #14
Sveen
Sveentusmaximus
Sveen's Avatar
Send a message via AIM to Sveen
I don't know what you are worried about there. Heck myself and BlueXJ welded & then put a torch to an almost empty gas tank to melt the solder and fill the holes a few weeks ago. Nothing happened
I am counting myself lucky and not trying it again though
Sveen is offline   Reply With Quote
Old March 4th, 2008, 10:50 PM   #15
vwBOY
it's how i roll
vwBOY's Avatar
let me guess its a ford hahah just did on last week pain in the ass
vwBOY is offline   Reply With Quote
Old March 4th, 2008, 10:56 PM   #16
Mjolman
1984 Jeep CJ-7
Mjolman's Avatar
I've heard damp cloth over fuel filler is helpful as well.
Mjolman is offline   Reply With Quote
Old March 4th, 2008, 10:57 PM   #17
Shotgun
I only wheel with boats.
Shotgun's Avatar
Thanks all!
yup, you are smart:miff::tonka:
Page generated in 0.40254 seconds with 74 queries
