83 f150 leveling kit - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2008, 09:03 PM   #1
fearnofish06860
fearnofish06860's Avatar
Default 83 f150 leveling kit
hey, i have a 1983 F150, 2 wheel drive, any idea where i might be able to find a front leveling kit for it?
fearnofish06860 is offline   Reply With Quote
Old February 22nd, 2008, 09:00 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
i bet if you googled it, you'd find hundreds in a second
Old February 22nd, 2008, 10:17 AM   #3
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
e bay
broncobuddha is offline   Reply With Quote
Old February 22nd, 2008, 11:01 AM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
2" spacers for $40/pair. If you need stud extenders they are $25/pair.
You will need adjustable ball joint slugs to align it.
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old February 22nd, 2008, 06:53 PM   #5
mooseracing
Stuck like a MoFo
mooseracing's Avatar
Send a message via AIM to mooseracing
If you're lucky you can align it after the spacers...alot of people have had to run the tuff country 1.5-2" drop brackets to get it aligned.
If it is actaully not level, throw a set of new front springs in to put it back at ride height.
mooseracing is offline   Reply With Quote
Old February 24th, 2008, 10:16 AM   #6
broncobuddha
Starting over
yeah its best to check which alignment bushings you have before putting in the spacers, they have to be at or very near 0 degrees to be able to get the alignment right after you put the spacers in, mine were 0 degree so it was no problem
Page generated in 0.24997 seconds with 41 queries
