Stuck Vehicle Recovery Safety. - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 22nd, 2008, 09:01 AM   #61
kickstand
circling the drain
kickstand's Avatar
that also doesnt provide a straight pull on the hooks and side loads them, I dont like that idea.
Old February 22nd, 2008, 09:28 AM   #62
95bowtie
like a rock
Ive gotta question for u guys. I have a 95 chevy it is my dd/weekend wheeler and I was looking at some tow hooks for it but i dont know what type tow hook would be safe. I was looking at some j-hooks but i would really trust them sence they would be bolted on upside down. Is there any way that i could fab up a d-ring mount to bolt to the bottom of the frame.
95bowtie is offline   Reply With Quote
Old February 22nd, 2008, 09:32 AM   #63
thrill20
thrill20's Avatar
Default How about this
Originally Posted by Roadhouse View Post
for anyone with a receiver hitch the tow strap shackle mount in Ironmans link is really great. I know most of you know that, but just saying for people who haven't seen one.
I have the Warn version myself.
I don't even own a 2" strap, only a couple of 3" straps. I did have a 6" when I wheeled my F250, but its over kill for the Heep. So I gave it to my buddy who bought the truck.
I can see the receiver hitch shackle mount being convenient, but is there any other benefit over just pinning your strap inside your receiver hitch? See pic. You're replacing the pin to receiver interface, the receiver to shackle pin interface, the shackle pin to shackle interface, plus the shackle to strap, with just a strap to receiver pin interface. It is much more simple, and should be just as strong.
Honest question, is there any reason this is a bad idea? I can see if you're pulling on an angle, the strap could rub on the edge of the hitch and possibly cut it, but on straight pulls is this acceptable.
thrill20 is offline   Reply With Quote
Old February 22nd, 2008, 09:35 AM   #64
fsumotorhead
N8KVB
fsumotorhead's Avatar
^i've done that hundreds of times
also i solely use a 6" strap, overkill in most situations yes, but i hate breaking straps and they add up fast. more than likely i'll not need a new one for a very long time.
Old February 22nd, 2008, 09:36 AM   #65
kickstand
circling the drain
kickstand's Avatar
I have used that method and see no issues with it.
95 bowtie you should look for some tow hooks from a 73-87 chevy, they were pretty beefy and always worked pretty well.
Old February 22nd, 2008, 09:39 AM   #66
fsumotorhead
N8KVB
Ford Superduty "hooks" are as tough as they come, if you have a solid frame point to mount them, i'd use those in combination with a shackle to attach a strap.
Old February 22nd, 2008, 10:03 AM   #67
Monster4.0
Monster4.0's Avatar
The only problem I see with that is the pin is made to be strong against sheering not bending.
Old February 22nd, 2008, 10:19 AM   #68
There is one downside to that. If you are in a situation where you are doing a sideways/lateral pull you can catch the strap on the side of your hitch which creates a very high stress point on the strap. Picture pulling a rubber band tight and hitting it wth a knife.
Straight pull.......... no problem.
Old February 22nd, 2008, 10:47 AM   #69
phazer42
I wheel, therefore I am
phazer42's Avatar
I posted this a few weeks ago in the rules and regulations portion of the forum....
note this information also covers the correct way to strap your rig down to your trailer when you are going to and from events, I have seen several rigs not properly strapped....
http://www.greatlakes4x4.com/showthread.php?t=75194
phazer42 is offline   Reply With Quote
Old February 22nd, 2008, 10:52 AM   #70
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
Originally Posted by Kodiak450r View Post
i have at least one tip no one mentioned. when your either winching, or using a recovery strap. i always like to make a U that connects to both side of the front hooks/shackles so that the pull it straight foward and not on an angle, this also distributes the load evenly on 2 tow points instead of just one. and if you need more then one strap to do this then run the U strap through the sown loop of the longer strap as shown below.
I do this also. all my military stuff has the two shackles on the front like most of the jeeps have. I have two 9ft straps or take one of my others and run it through the loop like described above. I like the second method better because it eliminates a clevis
fukkinrizzo is offline   Reply With Quote
Old February 22nd, 2008, 10:53 AM   #71
fukkinrizzo
this does not work for big straps
Old February 22nd, 2008, 12:25 PM   #72
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
I've done that too, but only for light pulls. You could bend the pin easily on a hard yank. I have an extra hitch insert with no trailer ball on it and I use my clevis hook thru the hole. Seems to work a little better then the strap into the receiver, especially if you have to pull at any angle.
71jeepster is offline   Reply With Quote
Old February 22nd, 2008, 12:26 PM   #73
smasheromalley
smasheromalley's Avatar
Anybody have a link to the old Cracker vid "The big stuck". Seeing it happen like that was pretty sobering I think.
Old February 22nd, 2008, 02:24 PM   #74
97xj
97xj's Avatar
Here are a few
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Who can forget these clowns without too much strap and not enough brains
YouTube Video
Here is one with just a broken strap.
YouTube Video
YouTube Video
YouTube Video
I should give a reminder to the Gals to always strip down to your bikini so that you can get some camera time
YouTube Video
97xj is offline   Reply With Quote
Old February 22nd, 2008, 02:51 PM   #75
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
I don't know about that. My buddy hit a car with his 250 and the factory tow point was bent and completely worthless along with the front bumper.
Personally I get my clevis or any hook from a place that sells quality units like crosby. I go to anderson equipment on 8 and middlebelt. you pay a bit more but imo worth it. I would stay away from those blingy stainless steel clevis's in the catalogs as well.
one thing I have seen a alot that has caused equipment failure is the stuck vehicle's driver not assisting the pulling vehicle. if you are stuck put it in gear and hit the gas appropriately (as not to run over the strap) and help the pulling vehicle. I can't stand the guy just sitting there waiting. most cases dictate that once you get the initial unstuck your vehicle helping provide power will greatly reduce the strain on the pulling vehcile. same with winches. if you are pulling use your vehicle in gear and ease the load on the winch.
Old February 22nd, 2008, 07:13 PM   #76
smasheromalley
Originally Posted by 97xj View Post
Here are a few
YouTube Video
thats the one
Old February 22nd, 2008, 08:31 PM   #77
badazzamc
Get Some
badazzamc's Avatar
Yes but if you use a d ring mount in a reciver the same amount of force is being applied to the pin.
Old February 22nd, 2008, 08:34 PM   #78
Not quite true. With an insert in the hitch, the pin is fixed all the way across with 2 shear points but it's not allowed to bend. In the instance of using just a pin to hold a strap, the pin is allowed to bend/ deflect. This is much weaker.
Old February 22nd, 2008, 08:40 PM   #79
badazzamc
Get Some
badazzamc's Avatar
yea thats true, I just dont see a pin bending, but I guess anything can happen.
Old February 22nd, 2008, 09:42 PM   #80
fsumotorhead
N8KVB
on top of that, i'm man enough to admit when i'm stuck and let off the gas before 100% of movement is lost. So i still have 6-10" to move around (in most cases) that way just before the strap is fully taught, i gun it and get the vehicle moving, it usually works great.
Page generated in 0.80753 seconds with 82 queries
