Stuck Vehicle Recovery Safety. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2008, 02:52 PM   #1
kickstand
circling the drain
kickstand's Avatar
Default Stuck Vehicle Recovery Safety.
This came up in another thread today, we have had a lot of new members join gl4x4 in the last year and it has been a while since we have discussed this.
Please use proper tow points, proper towing procedures, and care when doing a vehicle recovery.
This shit is serious business, people get hurt, dies, put holes in their hoods, etc.
I will get a picture of what a measly little tow hook did to the hood of my jeep when it let loose from another vehicle.
I do not want any pictures of what tow hooks and D-Rings have done to people.
This weekend is the chili run, there will be a LOT of people there, and there will be a lot of stuck vehicles in the mud, snow and ice. BE CAREFUL and use proper techniques.
If you do not know ask. If you see something unsafe, knock the person out of the way and show them how to do it safely. do not just stand by and talk about how dangerous it looks/is, go do something about it.
I would hope that others will chime in with proper techniques as I need to get back to work.
Thanks,
UP_ROKTOY and the safe recovery team.
Old February 21st, 2008, 02:57 PM   #2
http://www.greatlakes4x4.com/showthread.php?t=12168
Old February 21st, 2008, 03:00 PM   #3
kickstand
circling the drain
kickstand's Avatar
Thanks for the link
everyone take a second to look it over before you go out next
Old February 21st, 2008, 03:05 PM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
So whats wrong with the pin type clevis? I've seen people solely recommend the screw types before, i don't see what would be any safer about the screw type.
Seriously i want to know, cause i've been using the pin type for years without problems.
Old February 21st, 2008, 03:07 PM   #5
kickstand
circling the drain
kickstand's Avatar
it's possible for them to come apart. Not likely but possible. Also the screw in type are machined where the pin type are often cast.
Old February 21st, 2008, 03:10 PM   #6
fsumotorhead
N8KVB
cast what? I doubt a clevis would ever be cast, nor a pin
Old February 21st, 2008, 03:13 PM   #7
shaker
In the band!
The screw type clevis holds itself together making it harder for it to spread apart and snap. Were the pin ads no strength to the open end of the clevis.
shaker is offline   Reply With Quote
Old February 21st, 2008, 03:16 PM   #8
clarkstoncracker
lol
clarkstoncracker's Avatar
Like you know anything about vehicle recovery.. :tonka:
Old February 21st, 2008, 03:19 PM   #9
FORD FLARESIDE
6'-1" 185lb 14YO Griffin
FORD FLARESIDE's Avatar
Actually they are, especially if they are bought from someplace like TSC or Harbor Freight. I've seen some so bad, that the pin shaft is not even cylindrical, it is more in the cross section shape of an egg.
Old February 21st, 2008, 03:20 PM   #10
fsumotorhead
N8KVB
Thats the first time i've heard that, and the only explanation that made any sense
Old February 21st, 2008, 03:20 PM   #11
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
WOW!
hawkscj5 is offline   Reply With Quote
Old February 21st, 2008, 03:35 PM   #12
shaker
In the band!
I'm a slow learner but I'm getting there.:tonka:
The why is always very important to me to.
Old February 21st, 2008, 03:38 PM   #13
rallyemore
Snowman
rallyemore's Avatar
Send a message via AIM to rallyemore
Well I guess here is a good place to ask a question.
I read G-mans thread again, and it said to have your hooks pointing up. My hook is mounted upside down on my frame at the front of my vehicle and the point faces towards the rear, slightly curved up at the end. The strap has fallen off before, but other than that, I can't see a problem with it. I just have another person keep the strap taught until I can back up far enough so it stays on.
FWIW, this hook is huge, taken from a semi in a junkyard. I know the hook can handle it, but I don't know if it could have any adverse effects. Thanks in advance.
*edit*
Cliffs notes: is a hook facing backwards going to cause any trouble?
rallyemore is offline   Reply With Quote
Old February 21st, 2008, 03:40 PM   #14
Think of a horseshoe. You can grab it and pull it apart at the top of the "U". Now picture putting a bolt across the top of the "U" to hold them together. It's pretty strong. Now picture putting a pin with a hitch clip in place of the bolt. The only thing keeping it from coming apart is the 1/8 " diameter soft hitch pin. Not strong at all.
Now, there will be those that say that you are pulling from the pin to the bottom of the "U" so it doesn't matter. But what happens in the real world is 2 things. 1) there are still forces that try to spreat the top apart. 2) It has happened more than once where a clevis gets rotated during the movent of the strap.
The best clevis pins available locally (besides your local 4x4 shop) are the ones from TSC. The cost is next to nothing different than the unsafe ones.
Old February 21st, 2008, 03:57 PM   #15
97xj
97xj's Avatar
With the number of new faces it is a good idea to talk about it for a bit
Here is a well known image on the web of recovery gone bad. It speaks a more than a 1000 words can. Look closely at it.
97xj is offline   Reply With Quote
Old February 21st, 2008, 04:29 PM   #16
shaker
In the band!
*edit*
The hook at the end of wire rope (cable) should be attached point up. Because if something breaks odds are the line will fly towards the ground. But point down the line would fly up (usually about head level). With that said wire rope straps and anything else is never 100% predictable and is always dangerous when it breaks.
As far as a hook facing backwards. I'm not sure what you mean.
Old February 21st, 2008, 04:36 PM   #17
Shotgun
I only wheel with boats.
Shotgun's Avatar
CC will you sticky that post Gman did on this in the pub for the newbies and also in the proper area as well since most people spend more time in the pub it seems.
Old February 21st, 2008, 04:57 PM   #18
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
fukkinrizzo is offline   Reply With Quote
Old February 21st, 2008, 06:40 PM   #19
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
damn, the strap went all the way thru out the back!!
71jeepster is offline   Reply With Quote
Old February 21st, 2008, 06:47 PM   #20
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Notice The Drivers Seat Head Rest.
GNJEEPN is offline   Reply With Quote
Page generated in 0.50491 seconds with 82 queries
