88 98 lift options - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 19th, 2008, 10:37 PM   #1
elcaminokid
elcaminokid's Avatar
Default 88 98 lift options
got a 89 gmc k1500 and want to fit 33's under so i need a bit of a lift but don't want to spend like a grand on it i heard about torsion bar cam ioning but can't find one any where
elcaminokid is offline   Reply With Quote
Old February 19th, 2008, 11:13 PM   #2
thegoodfellas504
body lift
thegoodfellas504 is offline   Reply With Quote
Old February 19th, 2008, 11:20 PM   #3
bs_mudderz
bs_mudderz's Avatar
turn the tosion keys up or buy aftermarket keys and some good shocks it works did it to my buddies turned the keys up and shocks he clears 33''s check ebay motors for keys there cheap
bs_mudderz is offline   Reply With Quote
Old February 20th, 2008, 12:04 AM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
here is a link to the keys we put in at our shop http://www.readylift.com/
Old February 20th, 2008, 12:12 AM   #5
Ebs
You can swap in Ford keys (I don't have the part number on hand) and save yourself some money over buying aftermarket ones.
Old February 20th, 2008, 12:41 AM   #6
TS-Off-Road
989-832-4999
TS-Off-Road's Avatar
Made in Michigan!
http://www.suspensionmaxx.com/k1500.html
TS-Off-Road is offline   Reply With Quote
Old February 20th, 2008, 12:45 AM   #7
SBC YJ
Heavy Chevy
SBC YJ's Avatar
I put some on mine (aftermarket Keys) got them on ebay
SBC YJ is offline   Reply With Quote
Old February 20th, 2008, 08:04 PM   #8
elcaminokid
that is what i had been looking for is the keys just could not remember what they were called thanks for the input any other ideas feel free to add
Old March 24th, 2008, 05:16 PM   #9
dpalmer261
i clear 33's no problem with no lift on my 93 k1500, i just cranked the torsion bars up so it sat level and trimmed the bottom corner off my front bumper, cant even tell i did it either. have a look...
http://s264.photobucket.com/albums/ii168/dpalmer261/
dpalmer261 is offline   Reply With Quote
Old March 26th, 2008, 10:28 PM   #10
elcaminokid
no longer an issuse got a newer truck 1994 chevy ecsb k2500
fits 33s stock so now lookin for rims and tire deal o 33s or 35s
Old April 15th, 2008, 12:21 AM   #11
bbc_77_j10
bbc_77_j10's Avatar
Send a message via MSN to bbc_77_j10 Send a message via Yahoo to bbc_77_j10
all ifs chevy trucks require 4 inches minimum with trimming to fit 35s 6 with no trimming on 35s and you can squeeze 37s in with some substantial trimming on a 6 inch lift and most need either the torsion bars tightened up or keys installed to fit 33s, but be careful you dont just turn them up too far cause you will hyper extend your shocks and kill them really fast, trust me i did it, the key kits come with a shock spacer to eliminate that problem
bbc_77_j10 is offline   Reply With Quote
Old April 18th, 2008, 03:03 AM   #12
guest
Send a message via AIM to guest
You cna fit 33's on a stocl cehvy that body style. Many people have done it. Might have to do a little trimming. depends on your rim offset.
guest is offline   Reply With Quote
Old April 25th, 2008, 10:55 AM   #13
dpalmer261
mine is stock with 33's and all i did was trim of a tiny piece of the corner of the bumper and it only rubbed there when i turned allt he way, you can even notice i trimmed. i just got a 3 inch body lift and i have a set of 35's that i want to put on it but i dont want to have to trim my fenders or anything so hopefully they willf it and not rub that hard if they do at all. and if they do then i guess i will just get a 2 inch torsion key lift
Old August 15th, 2008, 10:41 AM   #14
DodgeitRamit
DodgeitRamit's Avatar
I have 35s on my 95 6.5 TD, 3" body lift and they fit with a little trimming of the bumper and bottom of the fender flare. Depends on the offset of the rim also.
DodgeitRamit is offline   Reply With Quote
Page generated in 0.45708 seconds with 65 queries
