quick d44 question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 18th, 2008, 04:52 PM   #1
mikef
Default quick d44 question
if got a half ton d44 front axle under the rig right now and am swappin over to a 3/4 ton here shortly. the 1/2 ton has a passanger side flat top knuckle that i want to use on the 3/4 ton. all i need to do is strip everything off the knuckle and bolt the 8 lug stuff back on. is that it? i believe so but i just want to double check before i waste my time.
mikef is offline   Reply With Quote
Old February 18th, 2008, 04:55 PM   #2
Toivo
Feel lucky?
Toivo's Avatar
you will most likely need to change spindles.
You didn't state what any of the D44s came out of, or what other one you are swapping in, so I can't help any more.
Be more specific before you end up with a large pain in the ass and incompatible parts
Old February 18th, 2008, 05:02 PM   #3
mikef
yea sorry, the axles are out of late 70s mid 80s chevy trucks, i dont know what years as i havent checked the bom numbers. the axles are/are going under an 88 chevy p/u. the half tons are under there and im swapping the 3/4 ton under there soon. when i said strip down the knuckle i meant hub, bearings, spindle etc.
Old February 28th, 2008, 05:09 PM   #4
Bronco Sally
Lets go wheelin
Send a message via MSN to Bronco Sally
so from 6 lug to 8 lug?? im pretty sure that the 1/2 ton axles have 6 bolts to hold on the spindles and the 3/4ton will have 8 bolts but im not all that familiar with chevs....
Bronco Sally is offline   Reply With Quote
Old February 28th, 2008, 05:33 PM   #5
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Then don't post as your info is wrong, everything will swap.
Scout=8 bolt spindle
Chevy/Jeep= 6 bolt spindle
Ford= 5 bolt spindle (90% of them, early drum brakes stuff was 6 bolt)
Page generated in 0.19217 seconds with 38 queries
